    Results 1 to 20 of 34
      Nov 2004
      Colorado
      DSE 4 link questions
      I'm pondering getting the DSE 4 link for my car. I have a couple concerns. I'm not sure I need $500 a pair double adjustable koni shocks. I'm not a autocrosser, I just want the car to be a nice cruiser. Are there any alternatives?
      Also how do you get exhaust around the panhard bar? The panhard bar is what makes true duals out the back a pita on 3rd and 4th gens.
      Also I would guess that this suspension would not need a rear sway bar?
      TIA for any comments.
      I don’t really see any adjustability in this system. Maybe I’m wrong but I’m not really a fan of a non adjustable 4 link as different cars need different geometry for different types of driving. In my car I would want the adjustability to move my instant center. I do see this as a 4 link with all of the binding problems being fixed so it should handle allot better then your average drag racing 4 link. You may want to look into the triangulated 4 link offered by air ride technologies, that’s a nice system for your application and you would have less of a hard time with exhaust. one thing that’s nice about a non adjustable system is there is allot less to screw up adjustability is a double edged sword
      Dayton, Ohio
      del
      Nov 2004
      Colorado
      Quote Originally Posted by RobM
      Would you know if they sell the suspension by itself? I don't want to use air springs, I want a standard coil over shock.
      Kansas City
      I am also trying to decide between the DSE 4 link and the air ride 4 link. Can someone go over the pros and cons of each??
      Oct 2003
      Arvada, Co
      One advantage of the DSE is the endlinks. All four link suspension have some bind in them. The DSE enlinks pretty much kills the bind in thier system.
      Brian
      Nov 2004
      Colorado
      I called DSE today. They told me that the panhard bar gets in the way of any stock type exhaust.
      I think the air bar is the way to go. They will sell the suspension without the airshocks.
      I'll probably be using QA1s all around.
      Anyone want to buy my edelbrock shocks and hotchkis springs?
      It is true that 4 links do bind but the rock crawler guys use them all the time and they have more articulation then any of our muscle car will ever come close to seeing. most of our cars have about 4 inches of travel that’s not a whole lot. I think a properly set up conventional 4 link would serve most of us just fine. However if one doesn’t know how the countless adjustments affect their vehicle they could possibly make their vehicle launch and or handle worse. the nice thing about the DSE and air ride set up is its pre set to be pretty close so there isn’t much room for error. if you do know how to set up the 4 link its possible to make your car accelerate awesome and handle pretty well too.
      Socal, Ca
      What about weight savings? Lets say DSE VS. air ride...
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by DJW32
      Well, the Air Bar system is pretty light.. we knocked almost 50lbs off the back of the car going from leafs to Air Bar.
      I would also think it's lighter than the DSE unit since it doesn't use a PHR.. I would call both companies and ask the weight of their systems to be sure. Oh, and that won't tell you the sprung/unsprung weight.
      Both are nice systems.
      1968 Track Rat Camaro:
      thing that most people forget about is balance of the vehicle sure its nice to have a light car, but if you take a ton of weight off the back and leave the front heavy the car could very well handle worse. Something to keep in mind. also id much rather take 50 lbs of un-sprung weight away then 100 of sprung weight. all things to think about
      Point A, yes, all four link systems inherently have bind. The issue lies in the fact that as the system rolls, at least one of the links needs to either lengthen, or contract, to eliminate bind. Point B? I'm not so sure. Unless there is some super cool deal that allows the link end to compress/contract, well, rotational freedom won't help a whole lot. The links don't suffer so much from torsional issues as they do from longitudial strain. Good thing the bushings are rubber!
      M
      Oct 2002
      Houston,TX
      Quote Originally Posted by EFI69Cam
      If all you want is a "nice cruiser" then dont even get the 4 link. Spend the money and time in other places.
      James J.
      agreed some times people don’t give leaf springs enough credit. No matter how you cut it keeping things as simple as possible for you application is the way to go. A good leaf spring is also capable of impressive handling
      Socal, Ca
      I agree...some people don't give leaf springs enough credit.
      If someone was going to run the air bar system minus the air shocks, how would someone figure out which QA 1 shock to run... Where would someone start...
      your easiest way to go would be to call QA1 and tell them you need a set up for a 4 link.
      Nov 2004
      Colorado
      Thats what I did. QA1 tech support is pretty good.
      Jul 2003
      Anaheim Hills, CA
      Yea, a good leaf spring set-up with say a bolt in watts link (ala the Fay's 2 deal) and you car could handle VERY good.
      About the worse part of rear leafs is the lack of adjustability..
      Santa Barbara, Ca
      I think most people would be suprised what a properly equipped leaf car can do. But here is another factor that applies to street driven cars: ride quality. Isn't a 4 link (DSE's for example) capable of far better ride quality with comparable performance to a good leaf system? I'm one of those guys who wants good handling, but also what a decent ride. I work on and drive BMWs all day, so I guess you could say I have pretty high standards. Their chassis engineers have it figured out. That is what I would like to get out of my car; Great handling/steering feel and a good ride (think M3). Those cars are just plain fun to drive. BTW, has anybody here actually driven a car with the DSE 4 link? If so, I'd like to hear about it.
      -Andy
      Nov 2004
      Colorado
      Quote Originally Posted by streetk14
      -Andy
      I agree with you. I want my car to be fun to drive.
      If leafs could be engineered to give an acceptable ride, why are even full size trucks going to a 4 link? The 1/2 ton Tahoes and burbs have a 4 link rear now. I looked at one, and the rear suspention looked alot like that on a chevelle or impala.
