    Results 21 to 40 of 51
      Feb 2006
      South West... Viva la New Mexico!
      while you are correct..... there is also a difference in driving in a circle a single direction versus going through a series of multidirectional turns.
      PA.
      It may be darn near impossible to make a stock framed Chevelle the equal of a C-5 on a road course but if it`s done right it`s possible to make it a match for a new GTO or Charger SRT8 which is a much more apples/apples comparison. Also don`t discount the "organic part" of each car in it`s total performance. ;) Mark SC&C
      Red Deer, Alberta, Canada
      Stop with the damn colors!!! I'm going crosseyed reading this. lol
      -Matt
      Matt
      Instagram: Cst_koon
      Feb 2006
      Quote Originally Posted by protour_chevelle
      -Matt
      but mom..... Dennis started it first lol
      Dec 2003
      lost
      I think you are incorrect! IMO (which all of this argument is really subject to personal preference ANYWAY) Actually I am not incorrect and it is not a subjective preference. I dissagree and yes it is purely subjective.... there is no way you can speak for every type and race team that is out there.... Actually, if you think about the cars that most of us are wanting to build, it makes more sense to use a progressive rate. Example... a car with a high static spring rate may perform well on the "twisty-turnsies" but as soon as you get it on the street it rides like a go-cart or if you take it to the drag strip she wont hunt for the hook up.</FONT>Why would a car with a high static spring not hook well. A/S is a function of design not spring rate. Guys running trick springs and the like do so INSTEAD of "fixing" the suspension.Wow.... I figured that one is obvious. it is a phenomenon in drag racing called weight transfer.I agree, however if you read a little more closely you see that I already pointed out the need for weight transfer is to cover up the poor A/S characteristics of said chassis. If you had 100%+ A/S there would not need to be much in the way of weight transfer to accomplish the same thing
      A variably progressive spring rate would aid in getting the tires back down to the surface faster which would be preferable to surfaces with a lot of bumps or surface transitions. No, a fixed rate spring is more likely to maintain contact as the progressive spring is lighter toward the end of the travel (the point at which tire contact is likely to occur) How can that be so if both springs share the same static spring rate?Variable rate springs are “variable”, what do you mean they have the same static rate. You must be trying to say the variable rate spring starts at the same rate as the fixed rate...that would one hell of a progressive spring. I don't think I have ever seen a progressive spring start at the rates I tend to run. "Two stars for you today Billy!!!!" "I don't think I have ever seen a progressive spring start at the rates I tend to run." Not only did you just make a statement that was not a hypothetical fact but it was admittidly personally subjective! That is awesome! See.. we are getting somewhere here afterall! I am stoked and glad to be of assistance Don’t get too excited yet. Just because I have figure out how to read your mind doesn’t mean we are getting anywhere. I still haven’t see your source for progressive rate springs that start with a base rate upwards of 800lbs which is what most guys serious about turning are running. To attain the high roll stiffness standards required for serious O/T driving the progressive rate springs offered would require monster sta-bars (not going there, I won’t, I won’t, I won’t).
      I also think that for your "average aggressive" driver a progressive spring rate would be better... again my opinion. Yes, your opinion. Anything that increases roll stiffness by X rate as it compresses/rolls will make predictability more difficult.
      "predictablity" I dont think is the word here.... instead I would use "tune-ability" and "slightly more difficult"...Predictability is very much a word here and very important. You need to be able to know how the chassis is going to respond to drive confidently. If one takes the time to tune and play with a progressive rate spring then I guess it would be predictable right? I do understand though that some people honestly do not have the capacity to add another variable to the equation... but that line of thought should also cut out adjustable shocks as well. You might as well say with time you could “learn” to anticipate how the bump steer and RC migration issues will hinder your chassis and anticipate their shenanigans.
      Now I will agree that with a professional or extremely smooth driver and a smooth groomed course a more linear flat rate is the way to go. Why would think there would be any difference just because the driver has more skill or the track is better groomed? A progressive spring rate will effectively control your unsprung weight more efficiently instead of leaving it purely to the shock absorber to control it. How do you figure? How does the spring increasing in bump/roll translate to a more effective control of unsprung weight? Simple man, as the suspension compresses and the contact patch lessens an increasing spring rate will exert increasingly more force to put the tire back on the ground. Versus a flat rate where the generated inertia will continue until it is eventually dissapated by the single flat spring rate. Actually I was referring to how you figure the shock is solely responsible for it in a fixed rate scenario. You are also ASSuming that the chassis has an imbalance because properly set-up there is no contact patch issue, which helps to prove my point. Using a fixed spring makes it much easier to tune the chassis to perfect balance. A variable rate spring becomes a variable, you constantly chase the imbalance that the spring is creating.
      I still think we should reopen the spring/air bag thread to continue this.I could care less about an airbag thread. I have my own (again) "subjective" opinion on bags although,I can see a very valid and very legitimate argument on the air bag side that has not even been brought up by the guy from air ride. This is clearly nothing more than a difference of opinion on spring rates which begun in this thread. Actually I was referring to the whole spring discussion in general as it relates to the air spring in theory very directly and doesn’t relate much with “70 Chevelle suspension” Obviously it deals with this thread because it was started here and actually you started it in this thread.....yeah, I know. I stated in passing, not looking for an in-depth, day consuming exchange.
      Added a new color just for fun!
      Feb 2006
      Not that many of us wants or can afford a Jerry Bickell pro-stock chassis. Not only that but I dont think they turn or slow very well without sending the laundry aloft. You again are refering to the perfect scenario which is not going to be the case with 99.9% of the readers or enthusiasts on this forum.
      having a base rate that high was simply an example to dissprove your "theory". In reality to get what most people are after, which is a car that will ride well and perform well at multiple tasks, using a spring that at least is a little progressive in nature is imperative. You will not get a car with 800 lb springs to be anywhere near anything that I would want to spend some time in.... especially not unless it had the curb weight and motion ratios of a Humvee. That is where a finely tuned progressive rate spring will shine. You can soften up the intial "impacts" and as the spring compresses slightly it will increase the spring rate to retail the handling and minimize roll. I will still argue the fact that progressive rate springs would still be superior to a flat rate spring in some racing applications, such as drag racing and some open tracks.
      In theory sure... but you are not talking apples to apples and you know it. Your reaching out in left field now....That would be the same as replying to your "go to a track and listen to the pit radios" with " If you listen to alot of C.D.'s, it makes you a musician!"
      I never said "solely"... that was the little voice in your head making you hear what you want to hear. to reiterate ( that means: to say again) I actually ( means: for really reals) typed... "more efficiently" . Based on your responses you on the other had are realistically... you are (how did you put it) "ASSuming" that every person on here has a perfectly balanced RACE ONLY car and RACES on a groomed perfect surface.
      I dont know about that..... watching you chase your tail is quite amusing.
      Feb 2006
      This is 100% incorrect. I don't care how well you understand suspension, you will never get your best 60ft times without transferring all the weight of the car to the rear tires. Anti squat allows the chassis to plant the tires. But without weight transfer you will only be planting the weight that is over the rear tires. For most of us that is less than half. Pro stock cars may be advanced in their chassis design, but they are also very light and have HUGE slicks. If you can get all the traction you need, then you don't need weight transfer. BUT...they have a very good weight distribution for drag racing as well. If you watch Pro-stock, you will see that the front tires are off the ground when they launch. That is weight transfer. Can't drag with out it!
      Nov 2002
      state of confusion
      I think this needs to be distilled down to something along the lines of "variable rate springs are more ride friendly" and "single rate springs are more predictable at or near the limit" and be done with it. Discussion without computations and/or results of instrumented testing to back it up isn't going to break any deadlocks.
      That said, variable-rate springs affect more than just the vertical suspension rate; they tend to make the suspension position sensitive as well as rate sensitive. That may be a good thing in the longitudinal direction, where both wheels on each axle rise and fall together. But I suspect it's not such a good thing laterally. For starters, the outboard side (under compression) will deflect a smaller amount than the opposite side will rise. Maybe this doesn't matter too much at steady state, but it will affect the way it "feels" during the transient portions that get you there and back. Perhaps enough progression in the spring to balance any falling rate tendency in the suspension might be a good thing, though . . .
      To tie this all back to the first statement and the ride comfort vs handling compromise, the handling "feel" during an 0.1g/sec transient that stops at 0.3g steady state or so is of very little significance compared to that during an over 3 g/sec event such as might occur while slaloming between 0.9g left and 0.9g right. In the ride comfort scenario, gaining a tenth of a second in a sweeper is absolutely without meaning when your frame of reference for time is the total time it takes to get from where you get into the car to where you get out of it. In competition that same 0.1 second can mean the difference of two or more finishing positions if the competition is particularly close. Apples & oranges . . .
      For your personal PT/G-machine/street fighter car, the questions that need honest answers first are "how hard do you drive?", "how often?", and "is ride or handling of primary importance to you?".
      Norm
      Gone but not forgotten dep't:
      Feb 2006
      here here!!!!!!
      In the longest sense possible... that is what I was attempting to iterate, sometimes I find it irrisistable to not be facetious and antagonistic...
      err, Don, I don't see a whole lot of parallel's to what you had been been screaming, in comparison to what Norm was stating. Further, coming from someone that thrives on a good debate, I'd politely suggest that you try to stick to the specifics, and less on the personal jabs?
      M
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by Mean 69
      M
      Down boy!!! Tomorrow, I'm gonna make this thread easier to read. Then it will probably be easier to understand. I got a headache trying to read what you ladies wrote, so I'm gonna fix it.
      Allen Ortega
      Feb 2006
      M
      (mean 68) In a nutshell, what I got out of Norms post was that this topic of debate is locked ( I agree). He also posted possible theoretical advantages and dissadvantages and that basically without data, ALL of this debate is hypothetical. Now what he really said that MADE me feel all warm and fuzzy inside, was his last paragraph. Which for some odd reason seems to be left out of a lot of responses.... now as far as your personal jabs comment goes, all of my jabs were above the belt and an attempt to keep the "debate" light hearted and I feel that anyone that has any kind of a sense of humor will easily see that....
      (Damn) I can see your reasoning and understand your explanation, I also do agree that a progressive spring rate will add to the tuning but in my opnion it is another tool, not a dissadvantage. I think a variable rate spring will actually be more advantages than always having to swap flat rate springs to get what you are looking for out of a tune. I do believe though that in order for it to be successfull that any and all varibale rate springs have to be used with quality adjustable shocks. That is one of the areas that I think is critical and I critisize the airbag side of it because I think every air suspension should have adjustable shocks and they dont do that... I dont agree with the position sensitive part though. Maybe my mind does not think that aggressivly but I feel that would add another variable crossover and would dynamically be to hard to tune. On the other hand, I do not see a variable rate spring and an simple adjustable shock absorber being all that difficult to tune. If you are familiar with the rate and inclination characteristics of the spring, you can easily adjust the shock to accomodate the depth of the suspension travel you feel you are going to be in for the type of driving you are going to be doing. In reality, it is all going to boil down to what makes sense in our mind.
      Don...
      Oct 2005
      Jasper,IN
      We may not send adjustable shocks in every kit, but all the Shockwaves come with 16 positions adjustable shocks and have an option for double adjustable, to adjust the compression and rebound independently. Also all the CoolRide kit are upgradeable to single and double adjustable.
      Nov 2002
      state of confusion
      Quote Originally Posted by DonQuehotey
      . . . I can see your reasoning and understand your explanation, I also do agree that a progressive spring rate will add to the tuning but in my opnion it is another tool, not a dissadvantage. I think a variable rate spring will actually be more advantages than always having to swap flat rate springs to get what you are looking for out of a tune. I do believe though that in order for it to be successfull that any and all varibale rate springs have to be used with quality adjustable shocks. That is one of the areas that I think is critical and I critisize the airbag side of it because I think every air suspension should have adjustable shocks and they dont do that... I dont agree with the position sensitive part though. Maybe my mind does not think that aggressivly but I feel that would add another variable crossover and would dynamically be to hard to tune. On the other hand, I do not see a variable rate spring and an simple adjustable shock absorber being all that difficult to tune. If you are familiar with the rate and inclination characteristics of the spring, you can easily adjust the shock to accomodate the depth of the suspension travel you feel you are going to be in for the type of driving you are going to be doing. In reality, it is all going to boil down to what makes sense in our mind.
      Don...
      As I understand it, shocks can be tuned to optimize one of three general requirements. Ride, best roadholding, or tuning transient understeer/oversteer balance. Or a compromise between roadholding and either of the others. For either ride or roadholding you're looking to achieve some percentage of critical damping, which is tied to the spring rate. That's the fly in the ointment - a sharply progressive spring will exhibit quite a bit of variation in rate over its range of position. You're correct that tuning some position sensitivity would involve a bit of additional effort (quite a bit, most likely).
      With arbitrary numbers for illustration only, it may be a 280 lb/in spring with the ride height 1" above the static position, but 420 lb/in at 1" below. Neither optimum ride (15% critical damping), optimum roadholding (~45-50%), nor a good compromise (~25%) can be satisfied for both of those rates simultaneously. For pure street use, choosing a damper that offers a little more than 25% critical damping for some intermediate rate would probably work acceptably well for nearly everybody. Slightly overdamped for best comfort, a little underdamped for best roadholding. Just not too much higher than 25%, or it may become too overdamped on the comfort side for the 280 lb/in position. And expect to replace them sooner if the roadholding is relatively more important; for as they wear they will only become relatively more underdamped for the 420 lb/in position. That's the good news, and is primarily of street/ride concern.
      The flip side is that the ride comfort curve is more sensitive to changes in damping % than is the roadholding curve.
      Transient tuning gets into things like tinkering with the actual time spent by the shocks in compressing or extending, which is affected by the amount of damping present. For all four corners, as the 'when' is as important as the 'what' part here. Suspension (and tire) loading are time-variable quantities here. Think
      [spring rate]*[displacement] + [damping constant]*[velocity]
      where all of these terms are inter-related. An acceptable compromise for the street is certainly possible, if perhaps not worth computing with any precision unless you're the OEM. For competition, this is what adjustable shocks can tune for you, but having a fixed relationship between the amount of damping needed and the [spring rate]*[displacement] term has to simplify things (if only the shock's construction and hence its cost).
      At this point, I don't think that any such application of position-sensitive shocks to progressive springs exists, at least not for street cars. The closest that I'm aware of is Monroe's Sensa-Trak (sp?) line. Bypass grooves cut for the range around static ride height to "dump" some damping that are closed off as the piston moves either direction away from static. No reason you couldn't use a similar approach to progressively kill off excessive damping as the shock extends, just that it's not an available off-the-shelf or easy-rebuild option.
      [Off-topic and constructively intended] - It probably takes more than a month's membership and 20-odd posts for people to "get to know" a new member. Attributes like technical strengths and style of humor are unknown quantities. Remember, the "body language" clues that are available in a face to face discussion are nonexistent here (smileys can only do so much even when they're used). Even a telephone conversation provides more clues by way of such things as the "tone of voice".
      Norm
      Mountain View, CA
      Don...
      The thing most people miss is that the shock can only be tuned to damp one "area" of that progressive spring at a time. "It has 16 settings" blah blah blah, means nothing. Sure you can set the shock to appropriately damp the light end of the spring for cruising, but then the upper end is grossly underdamped and therefore not conducive to "comfort". You can stiffen things up for a track-day or autocross, but then the initial travel us vastly overdamped.
      Yes, you can adjust the shocks "stiffer" or "softer" but that only adresses a portion of the springs travel. Not to mention the associated niggles that come along with excess damping against a light spring and vice-versa.
      The spring will continue to use all of its travel despite the fact that a good portion of it will be damped incorrectly. Unless you've found a way to not use portions of your springs travel in certain environments?
      The one and only way to effectively run a progressive spring is to use position sensative damping. If tuned correctly you can have nice compliant movement in initial travel and solid, controlled movement deeper into the range.
      True T.
      My blog
      Mountain View, CA
      Quote Originally Posted by Norm Peterson
      Norm
      Norm,
      An additional problem associated with a progressive rate is the matter of the damper. Can you tune it to control the 500"lb side? Yes. Can you tune it to control the 700"lb side? Yes.
      Can you tune it to control both? Nope.
      That is the salient point in my argument regarding progressive air springs as a performance suspension component.
      It can be done through the use of position sensative dampers. But that is not what ART is using.
      True T.
      My blog
      Great point, I was thinking of that too. But, in the case of virtually every progressive rate spring I have seen, the soft windings are very short relative to the firm portion of the spring. The softer stuff takes care of the small, high frequency bumps, like the stupid little reflector markers, small-ish potholes, etc. There is so little relative travel that even if not appropriately damped (and it will be somewhat close, unless the ratio of the two rates are grosly different, which would introduce a whole other fun set of problems, the phrase "turn in" might become something like "whoa baby, come on already!"), you wouldn't get appreciable oscillations, etc. Or you shouldn't, anyway.
      I can say that I only have had these types of springs on one of my cars, a later model Mustang years ago. I couldn't even comment on the difference between them relative to a linear rate spring, didn't feel any different to me, but I honestly didn't pay that much attention.
      M
      Oct 2005
      Granger,IN
      I read the links listed in the first few posts and all I could distill from them was that several people seem to think there is not a good suspension setup for A-bodies which still use stock suspension mounts.
      Did I miss a good suspension option? Is there a good option if the stockmoutns are cut off and repalced?
      Free hostings of solid models!
      http://www.wrenchmonkey.com/Webpages/Solids/Solids.html
      92 Stealth Twin Turbo with 3.5L Engine swap
      Looking for my next project, maybe an AWD 71 Lemans????
      Gong show.
      -Matt
      Matt
      Instagram: Cst_koon
      Feb 2006
      Enumclaw, WA
      Now with the airbags I could optimize the suspension a a certain heigth then the other settings would be to lower it for shows or cruises and raise for bumps?? That sounds good to me...
