      what to run for timing
      i have an complete msd set up, and am curious as to what i should run for timing. the motor is a 414 bbc with 11:1 cr, a 236/242 612/612 lift cam demon 850 carb, aluminum heads, and will be run on 93 octane pump gas. any help would be great.
      also when first installing the dist. whats the proper way. is #1 cylinder supposed to be a TDC? and line up the rotor with it or how is it done?
