    Thread: low oil presure
      low oil presure
      my question is when im driving my presure is at 30 to 50 on my gauge(auto meter elec) but when i come to a stop it drops to 10 or 5 what could be some of my problems ? i just installed a solid lift cam and a tko 600 and the motor is a 383 stroker and only has 300 miles on it. help please?
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by morris69
      As Im sure youre painfully aware thats too low for a fresh motor. What was the pressure when you first fired it up before putting 300 miles on it. Higher, lower, same? Have you cut the oil filter apart to look for debri? If so whatd you find?
      Verify elec gauge is correct by swapping in a mechanical gauge.
      Main/rod/cam bearings damaged or wrong clearances.
      Bypass in the oil pump stuck open (only seen this once).
      One or more of the oil galley plugs behind the cam gear has flipped or completely blown out.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      Nov 2004
      I think this is relatively common for a motor that has been assembled with loose clearances. I would get the engine builder's recommendation on how to proceed. After checking the basics, you may want to try a different oil viscosity (perhaps 15W-50) that is designed for looser clearances before tearing it apart. I've also heard of people experiencing this problem when running a Fram filter - but I have no idea why.
