Thread: Rear drum-disc on G-Body
02-14-2006 #1
New to Pro-Touring
- Jan 2006
- Florida
- 16
Is there a way to convert to rear disc using a donor(if so what) and would I have to do any welding; or would I be better off buying a kit. 80 Malibu.
02-16-2006 #298-02 camaro stuff will work.
02-18-2006 #3
- Feb 2006
- Lexington, KY USA
- 4
Hello,
A possible donor would be 1993-1997 F-body, but it will require some welding. The axle flange on the F-body is a rectangular 4-bolt flange, and the G-body has the 3-bolt flange. It's probably best to weld the brackets to the axle flanges.
I have G-body brackets from Baer that I'm using on my S-10 truck (which use the F-body calipers), and they clock the calipers at the 4/8 O'Clock position. The Baer G-body instructions mention a bracket to relocate the shocks, but I haven't seen such a bracket (my Baer kit was pieced together with Baer -- very helpful bunch!).
If I were to get a kit I'd buy the Baer kit, but if you're up to some welding then an F-body donor isn't a bad route.
02-19-2006 #4
