      Which SS brake lines do I need?
      I am installing C4 Vette ('88-'94) front disc brakes and LT1 ('93-'97) rear disc brakes on my 1969 Camaro. What Stainless Steel brake lines do I need to complete this swap?
      Will the '69 camaro stock cable fit the rear setup listed above?
      I have no problem making/using new flare fittings (single or double).
      Brandon
      Colorado
      Dude, just call Laramie Torres at Precision Brakes 866-992-7253. He has the lines to do what you want. The problem is the brakes you are using have bubble flare fittings and your car has double flare fittings. I am in the middle of a similar brake swap and he got me hooked up with the right lines. He knows the correct lengths and fittings for each end of the lines.
      Brett
      Brett,
      Thanks for the tip! This is just the info that I was looking for.
      Brandon
      Colorado
      Not a problem.
      Laramie is the man he hooked me up with the lines also!
