      1969 Camaro Rear E-Brake Cable - Lokar help?
      I am installing LT1 ('93-'97) rear disc brakes on my 1969 Camaro. What Lokar e-brake cable do I need?
      I want to run my factory e-brake pedal and intermediate cables.
      Would this part work (LOKEc81fu) - I believe it is available at Summit Racing?
      Brandon
      that is for their e-brake set up. You can call them with your needs.
      67 Pro-Touring Camaro
      ISMAIL
      That is for their e-brake set up. You can call Control cables with your needs.
      ISMAIL
      CT
      You could use a rod, 7"'s or so which would be threaded inside one end which the factory threaded cable would srew in and the other end drill a hole which the lokar cables would connect to. I bought the universal cables and had the rod made, but I was using 79 rear brakes. I recently changed them to the lt1 style. So I haven't mounted the lokar cables on the new brakes....
      I believe ATS has something for this.---------------->
