Thread: LT1 in a 72 Cutlass
- Oct 2004
- Austin,Tx,
- 154
LT1 in a 72 Cutlass
I've got a buddy who has a lt1 he wants to put in his 72 cutlass, the car currently has a 403 olds motor in it. wWe wanted to know what would be needed to mount the motor in the car. ( could we get a set of mounts for a smallblock chevelle maybe?) He also has the tranny (460le?) to go with it. I know this has been done dozens of times in chevy cars but has any one done it to an olds? Also what modifications need to be made to the gas tank in order to update his fuel system? The motor will probably require a decent amount of fuel as it is a supercharged LT-1. Thanks in advance for the help.
Paul
1969 RS Camaro
1985 Buick GN
2005 F-250
02-13-2006 #2a change to a small block motor mount wil be requiered,the motor is the same a small block chevy(reg).it will bolt right in,you will need a computer and fuel system upgrade,an areomotive fuel system will work fine.sumped tank and fuel return lines,the 4l60e should bolt right in,a good non computer is a 200r4.the olds frame is the same a chevelle,so anything for a chevelle will work.
02-16-2006 #3
- Oct 2004
- Austin,Tx,
- 154
rocketman, Thanks for the reply. Is the part that attaches the motor mount to the frame (not sure what it's called) different on the cutlass than on the Chevelle?
1969 RS Camaro
1985 Buick GN
2005 F-250
02-16-2006 #4
