      Baer Brakes Serious Street?
      Who runs these? I really want to put the Track system on with the 13" rotors, but I can't afford rims and tires to fit. To many others things I need first.
      But I do need good brakes. I was thinking I'd get the Serious Street front setup for now, and then switch over to the Track system later. However, I was talking to Baer and they said it wouldn't save me much money.
      So how does the Serious Street setup do? I'm looking at $300 for a new booster/mc for what I have now, or $900 for the Baer kit.
      Thoughts/ideas?
      Oakland CA
      Im in the same situation. Thought i might upgrade but rims and tires just makes the price go quite high. and i have to decide by tommorow morning...
      David
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      San Diego
      I just finished installing the Serious Street system on the front of my 68 Camaro. I still have drums in the back, but with just the front discs there is a noticeable difference in stopping power.
      If you need a new booster, you should know that the booster is not included in the Serious Street kit, only the master cylinder.
      Santa Barbara
      I just got the Baer track fronts and disc rears they are great and have helped in feel and braking overall a fair amount but adding hydroboost was the biggest improvement by far for me. I did have factory style disc brakes on the front before the new Baers though. I would suggest looking at hydroboost as an part of an overall system or even a bandaid until you spring for the Baers.
      Hmm, I was pretty sure Baer told me the booster was in the kit. I'll have to make double shure that it's availible before I decide.
      Nov 2002
      Georgetown,TX
      Power boosters are an extra cost option with Baer brake systems.
