    Results 1 to 9 of 9
    Thread: oil cooling
      Feb 2006
      s.f. east bay california
      oil cooling
      I am ditching my automatic tranny in my truck for a non overdrive 5 speed manual and was wondering if I could use the secondary cooling loop in my radiator for the oil. I saw the guys on dream car garage plumb thier oil cooling through thier radiator on thier vintage racer corvette but it was an after market piece. Would the secondary pluming in a factory radiator be big enough to not cause oil pressure problems.
      Dog will Hunt
      Newbury Park, CA
      Nope. Not big enough. For most oiling systems a 5/8" line (-10AN) is needed.
      The guys on DCG used the same cooler that is in mine. Spec's are on my website. That Corvette was very nicely put together.
      You can have a stock GM oil cooler put into the return side of your radiator. Many radiator shops have the coolers laying around from old radiators and they can be adapted to yours.
      Feb 2006
      very nice
      Thanks for the link. It was very informative. I am in the proces of putting spring adjusters in the back of my truck its a 68 chevy if your wondering. I just got done putting a fuel cell under the bed behind the axle and I fabd an adjustable track bar mount so I can keep the bar level when I change the ride hight. It is going on a savear diet soon to but how is a secret.
      Dog will Hunt
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by CarlC
      I had the same thought, using an otherwise unused tranny cooler. If the cooler is too small, would that result some kind of restriction and could cause oiling problems, or would it simply be ineffective?
      What about using the trans cooler for p/s cooling?
      Scott from NJ.
      Vent Windows Forever! ...
      Newbury Park, CA
      It would be too small and cause a system restriction since all of the oil routes through the cooler.
      Vibrations in the PS system can be an issue when used with the stock AT cooler. Round tube coolers are preferred. There have been a few people who have done it and it seems to have worked OK for them, but long-term durability is unknown.
      Central CA USA
      I pulled apart a chevy pickup radiator, it had a copper plate type oil cooler in the hot side tank. The trans cooler was brass.
      Feb 2006
      And
      What does that mean if anything.
      Dog will Hunt
      Central CA USA
      It means that if you go to a radiator shop, the copper cooler with large ports is the one to get, at least for a Chevy pickup cooler. If they hand you a brass cooler with small ports, it's for power steering. Not very useful info, I admit!
      Aug 2005
      Hamilton, NJ
      Thanks-
      Scott from NJ.
