    Results 1 to 10 of 10
      Flint, MI
      Alittle Humor For The Day!
      An explanation of the tools of auto repair as found in a garage.
      HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
      as a kind of divining rod to locate expensive car parts not far from the
      object we are trying to hit.
      MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
      cartons delivered to your front door; it works particularly well on boxes
      containing convertible tops or tonneau covers.
      PLIERS: Used to round off bolt heads.
      HACKSAW: One of a family of cutting tools built on the Ouija board
      principle. It transforms human energy into crooked, unpredictable motion,
      and the more you attempt to influence its course, the more dismal your
      future becomes.
      VISE GRIPS: Used to round off bolt heads. If nothing else is available,
      they can transfer intense welding heat to the palm of your hand.
      OXYACETYLENE TORCH: Used almost entirely for the lighting those stale
      garage cigarettes you keep hidden in the back of the Whitworth socket
      drawer (What wife would think to look in _there_ ?) because you can never
      remember to buy lighter fluid for the Zippo lighter you got from the PX at
      Fort Campbell.
      ZIPPO LIGHTER: See Oxyacetylene Torch.
      WHITWORTH SOCKETS: Once used for working on older British cars and
      motorcycles, they are now used mainly for hiding six-month old Salems from
      the sort of person who would throw them away for no good reason.
      DRILL PRESS: A tall upright machine useful for suddenly snatching flat
      metal stock out of your hands so that it smacks you in the chest and flings
      your beer across the room, splattering it against the Rolling Stones poster
      over the bench grinder.
      WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under
      the workbench with the speed of light. Also removes fingerprint whorls and
      hard earned guitar callouses in about the time it takes you to say, "Django
      Reinhardt."
      HYDRAULIC FLOOR JACK: Used for lowering a Nova to the ground after you
      have installed a set of drop springs, trapping the jack handle firmly under the front bumper.
      EIGHT FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a
      hydraulic jack
      TWEEZERS: A tool used for removing wood splinters.
      PHONE: Tool for calling your neighbor Ryan to see if he has another
      hydraulic floor jack.
      SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
      spreading mayonnaise, used mainly for getting dog-doo off your boot.
      E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is
      ten times harder than any known drill bit.
      TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup on
      crankshaft pulleys.
      TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
      strength of ground straps and hydraulic clutch lines you may have forgotten
      to disconnect.
      CRAFTSMAN 1/2 X 16" SCREWDRIVER: A large motor mount prying tool that
      inexplicably has an accurately machined screwdriver tip on the end without
      the handle.
      battery ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
      from a car battery to the inside of your toolbox after determining that
      your battery is dead as a doornail, just as you thought.
      AVIATION METAL SNIPS: See hacksaw.
      TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop
      light, it is a good source of Vitamin D, "the sunshine vitamin," which is
      not otherwise found under cars at night. Health benefits aside, its main
      purpose is to consume 40-watt light bulbs at about the same rate that 105
      mm howitzer shells might be used during, say, the first few hours of the
      Battle of the Bulge. More often dark than light, its name is somewhat
      misleading.
      PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
      paper-and-tin oil cans and splash oil on your shirt, it can also be used,
      as the name implies, to round off Phillips screw heads.
      AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
      power plant 200 miles away and transforms it into compressed air that
      travels by hose to a Chicago Pneumatic impact wrench that grips rusty
      suspension bolts last tightened 40 years ago by someone in Abingdon,
      Oxfordshire, and rounds them off.
