Results 21 to 40 of 50
Thread: License plate angle
01-26-2006 #21
I made my final decision yesterday and im sticking with it. I am going to countersink a box into the rear of the car. I guess this is called a "French plate" I knew what I wanted to do just wasnt sure what it was called. It will be very very similar to this pic I did yesterday with post #87 in my exhaust thread.
Thanks again for the feedback. I am very excited to do the French plate idea. I just need to find a place I can buy one or I will just make one myself. Those stupid pegs will be gone.
Deleted old pic
01-26-2006 #22Cool....
I think that is by far the best way to go Adam. It won't look like an afterthought this way. Speaking of legalities, what are you going to do for a light on the plate? I think here in Fla. you have to have the tag lighted at night. That damn light is gonna be much more important than the angle I think.
frenching:
The customizing process of creating smooth curve shaping around the headlights, tail lights, licence plate frames, etc. so that the actual lights, etc. recede a little towards the interior of the panel opening and the chrome bezel or other surround looks as though it is part of the body panel.Last edited by Jagarang; 01-26-2006 at 05:15 AM.
Kevin.
69 Firebird "Eternity"
01-26-2006 #23Thanks Kevin,
I am sooo excited to do the Frenched Plate idea. I mentioned in my exhaust thread that I will install a LED light into the top of the box. Very very easy to install. I cant wait. Actually I am almost too excited to order a box. I might just make my own tonight.
01-26-2006 #24Ahhhh...I thought you'd said in the other post that you were going to install a third brake light....my boo boo...
Take a break from that thing tonight and let me kill you a bit!!
Kevin.
01-26-2006 #25
I might be on Halo tonight but im supposed to meet someone in a computer game tonight to kill them instead. Hmm mabey I should take a break tonight and just order a box to install that way I dont have to bend it myself since I dont have a press to bend it properly.
01-26-2006 #26Book, book bok boooooook!!!(Chicken noises for those not fluent in coward!)
I'm calling you out CHICKENBOY69!!!!!
Kevin.
01-26-2006 #27Ut oh I just found out we have a break press at work that I can use!!! I could bend that French Plate myself.
So I might not be on tonight not sure yet.Adam_______Offical Car Name "ILLUSION"
01-26-2006 #28Buy the box....
your just looking for excuses you lilly livered yellow back!
Kevin.
01-26-2006 #29If I could find a Frenched Plate already made i would rather go that route. Anyone know where I can pick one up???
Kevin,
You must really be phening for the salty taste of my tea bag in your mouth again.
01-26-2006 #30Chickenboy69
Chickenboy69chickenboy69chickenboy69chickenboy69ch ickenboy69chickenboy69chickenboy69chickenboy69chic kenboy69chickenboy69chickenboy69chickenboy69chicke nboy69chickenboy69chickenboy69chickenboy69chickenb oy69chickenboy69chickenboy69chickenboy69chickenboy 69chickenboy69chickenboy69chickenboy69chickenboy69 chickenboy69Last edited by Jagarang; 01-26-2006 at 06:12 AM. Reason: Waht's your excuse now....
Kevin.
01-26-2006 #31I am searching right now to see if I can find a place to just buy the "Frenched Plate" If I cant find a reliable source then I will have to make my own.
01-26-2006 #32KOOL TAG http://www.goodtimeproductions.com/catalog.html
FRENCH LICENSE PLATE KIT
Weld in tag frame made from 18 ga. steel
Close fitting 12 volt tag light
16 ga. electrical wire and bullet terminals
Tag and light mounting hardware
Installation sheet
Dimensions: 13" length x 7 1/4" height x 3" depth
Only $49.83
Also...
http://www.dakotastreetrods.com/cata...oducts_id=2164
http://www.aardvarkcycle.com/builders%20kit.html
Just the box...without a kit
http://www.stylinconcepts.com/parts....categoryID/226
http://store.gaugemagazine.com/index...OD&ProdID=2314
http://www.streetbeatcustoms.com/licplatboxst.html
HERE'S A PINK(or YELLOW) neon frame you can put in with it!!
http://froogle.google.com/froogle_cl...--------------
Kevin.
01-26-2006 #33WHoa how did I miss this thanks Kevin. I will check them out an make a decision.
01-26-2006 #34I just found this one I like a lot. I can even get the LED light and 3rd brake light. http://www.watsons-streetworks.com/license_plate.html
01-26-2006 #35I also found this one....
How bout a....
Kevin.
01-26-2006 #36I am going with the kit that I listed in post #34. I am not going to get the 3rd brake light though.
This is whats in the kit.
The 18 ga. steel box is 12-1/2" wide by 7" high and 3" deep (for standard 12 x 6 plates) and has been clear zinc plated to prevent corrosion before you add paint. PLUS two of our exclusive Bright White LED Illuminators for the plate, predrilled holes position the LED's above the plate. PLUS a 32 LED third brake light that attaches to the top of the box (inside) in a perfect location to be seen from behind. Quality 3M Adhesive provided for mounting. PLUS Stainless Steel License Plate bolts. PLUS rubber grommets to help seal around the bolts and hold the plate away from the paint.
#L54 Everything including LED lights and Brake light $125.00
#L54-X (L54 without the 3rd Brake Light) $95.00
#L54-BOX (Steel box only) $65.00Adam_______Offical Car Name "ILLUSION"
01-26-2006 #37I just ordered that kit above without the 3rd brake light.
Looks like I get to kick your butt in Halo 2 tonight Kevin. I will get the tea bag ready for you.
01-26-2006 #38Try something from street rodders - Paint the plate on your rolled pan. The plate is a number reference only. If the current tag stickers are in place, you have nothing to worry about. This becomes a bummer if you sell the car, however.
The other is the flip down license plate holders. Simple but really effective. Tie it into the ignition switch to actuate and retract when the key is turned off.
I wouldn't mess up the back end of your car. I like the exhaust in the center.
01-26-2006 #39Toss some tabassco on there Adam....I like it spicey!
This will be me sanctifingyour passing friend.......
http://www.bungie.net/images/News/To...icHumpday4.gifLast edited by Jagarang; 01-26-2006 at 07:33 AM.
Kevin.
01-26-2006 #40
Originally Posted by Jagarang
I love that Halo 2 avatar!!!
