      Hayesville,NC
      Trick Flow Heads for SBC ?
      I have a buddy of mine wanting to sell me a set of brand new Trick Flow heads for my almost stock 350.I was thinking of them and a cam swap.I have a 1981 camaro with the stock 350w/stock heads.It has an Edelbrock perfomer RPM intake,Holley street avenger 670,Summit hei dist and MSD plug wires,Flo-tech afterburner headers w/flowasters and 2 1/2" exhaust.What would be a good cam choice to maximize power and still not be too much? As you can tell I'm new to this so all help is greatly appreciated.Oh yeah, it has an auto and 3.08 gears,soon to be swapped for a 200r4 and 3.73's.
      Nov 2004
      NW Arkansas
      What size are the Trick Flow heads?
      KENNY DAVIS HOTRODS
      Hayesville,NC
      It's the kit from Summit TFS-K314-350-400 put in a GM crate 350 long block 260hp/350tq.I just want to change the cam and go.Just need to know what would be the best cam choice.
      The cam it it now is 210/[email protected] .440/.454 w/1.5 rockers 110 degree lobe
      the heads 64cc 195cc intake 1.25 valve springs (360lb spring rate .520 " lift)
      Nov 2004
      NW Arkansas
      Quote Originally Posted by 1981silverz28
      that should be enough info for one the experts on here to give you an answer!
      KENNY DAVIS HOTRODS
      GM has a few cams that would work.
      GM PN 12370846... 222/230 112LSA
      I would run that with 1.6 Rockers and a valvespring like a Comp Beehive.
      You can always go with a custom cam to really tailor the cam to your setup.
      Bret
      Bauer Racing Engines
      Specializing in late model GM motors
      1964 GTO (work in progress for 13 years)
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Not gettin done anytime soon
      2000 Camaro SS SCCA FS Car
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
