    Thread: primer question
      livermore ca
      primer question
      iam useing featherfill g2 on my car can i put bondo on top this primer? also i heard it was a good ideal once i sprayed the whole car and everything this straight that it is a good ideal to spray a uerathan primer over top it becuase u cant wet sand the featherfill and i could wet sand the other primer and u would get a smoother finish
      thanks chris.
      Oct 2005
      Odessa mo.
      I'll ask my paint rep tomorrow. I'm not familiar with feather fill but we spend 20,000 a month with him so I know I'll get you the right answer
      Dallas, TX
      yes, you can apply plastic fillers over the Feather Fill. both are polyester based products.
      always, and I do mean always use a urethane primer after before topcoating. if you don't the polyester resin in the primer filler and plastic filler will suck up the paint like a sponge and you'll be back at square one.
      good luck.
