      63 nova brake help
      my friend and i would like some advice on which booster and master cylinder to use with cutlas bront brakes and 3rd gen rear discs?
      thanks guys
      Try a booster/cylinder combo for a 67 Nova. The master cylinder they give you with that unit should be the same as they would with a 68 Corvette with rear disc. Make sure the firewall mount and pedal pushrod mount are compatable with your car. The pedal pushrod will mont lower on the pedal, so you might have to drill. Check 67 Nova. The pedal pushrod needs to be centered to the booster input, not at an angle to it.
      thanks for the help i appreciate it
