    Results 1 to 13 of 13
      Feb 2007
      Tinley Park, IL
      iBooster vs Vac Pump
      While my engine is being rebuild, I collected parts and began installing a Hydroboost system. For various reason, I don't want to continue with the Hydroboost. The latest and greatest seems to be the iBooster, but there are also modern vac pumps options to use along with a normal vac booster.
      The combo I've been running for years is as follows. I had no issue with how it felt during normal use, but it did lack stopping power in any type of panic or aggressive braking situation.
      • Dual diaphram 9" booster with 1.125 master cylinder
      • KORE3 C5 base front & rear disc kit
      • EBC red pads
      • Braided hoses
      • From memory the engine made around 15 in hg at idle (manual trans)
        • new engine will be cammed similarly and probably make similar vac
      I don't mind spending the money on an iBooster kit if it truly is better for me. My daily driver is a 2026 Bronco which has electric assisted brakes and I have no complaints overall. Is the iBooster just the flavor of the week, or is it really the way to go? What do I gain over simply adding a modern vac pump like the options I've shown below?
      Car is a semi-daily driver, weekend cruiser, Power Tour type car. Autocross and drag racing for fun. New engine should make around 525hp.
      $1,440 with the required Wilwood MC https://www.retrofitinnovations.com/a-f-x-body-gm-cars
      $425 mounts under the vac booster, reuse MC I already have https://www.studiohotrods.com/product-page/boostmaster
      $389 mount yourself wherever you want, reuse MC I already have https://leedbrakes.com/i-23439165-el...it-series.html
      Thank you.
      Nick ~
      1969 Cutlass
