      Oct 2005
      New Washington, IN
      What would these cams do?
      Looking at these two cams.
      It will be for a 400 pontiac with edelbrock heads, rpm intake, headers, 9.5:1 cmp. Street car, weekend cruizer. 5 speed. A bit of a lope or rough idle would be fine, don't want it to sound wimpy!
      Cam 1
      Basically, RA IV cam
      Lobe sep. 113 duration 304/316
      Duration @ .050" 231/240 lift .470/.470
      Cam 2
      lobe 110 duration 302/302
      @.050 242/242 lift .507/.507
      Both are hyd. flat tappet.
      mo
      cam 2 will sound better with the tighter lobe sep and be more perf with the higher lift.cam 1 will sound ok with the duration but the wide centerline will cause it sound weaker.
      Oct 2005
      New Washington, IN
      Thats what I was thinking. Do you think there would be much difference in terms of performance?
