    Results 1 to 13 of 13
      Jul 2026
      Az
      67 camaro project
      Hello new here, im building this car and have already made progress ill post as many pictures to catch up to its current state. I do alot of fabrication and electrical diagnostic I know alot but not everything and would love input or criticisms I know there are incredibly smart people here so if im screwing up please let me know. And go easy on me with my body work I'll be posting all the pictures
      Jul 2026
      Az
      This is how I bought the car I had even cleaned it before this picture. And the next car I get will be farther along than this one that's for sure!
      Jul 2026
      Az
Size:  198.7 KBName:  20250622_084644.jpg
Size:  348.5 KBName:  20250622_145508.jpg
Size:  292.8 KBName:  20250622_165556.jpg
Size:  349.0 KBName:  20250622_112417.jpg
Size:  195.5 KBName:  20250625_123722.jpg
Size:  391.6 KBName:  20250625_165613.jpg
      Trying to straighten everything i can before I start skim coating
      Jul 2026
      Az
Size:  433.5 KBName:  20250701_192758.jpg
Size:  430.1 KBName:  20250701_193522.jpg
Size:  377.2 KBName:  20250703_221402.jpg
      Dash panel was bad so it had to go rust was forming in the corners.
      Mountain Springs, Texas
      Impressive work straightening that metal!
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2026
      Az
      Thanks man body work is definitely not my favorite!
      Jul 2026
      Az
Size:  276.8 KBName:  20250707_130200.jpg
Size:  270.5 KBName:  20250707_145646.jpg
      Small amount of rust on the lower quarter had to cut it out.
      Jul 2026
      Az
Size:  363.3 KBName:  20250728_203601.jpg
Size:  373.9 KBName:  20250803_162448.jpg
Size:  373.1 KBName:  20251018_201017.jpg
Size:  267.5 KBName:  20251026_192757.jpg
Size:  296.5 KBName:  20251027_192315.jpg
Size:  330.7 KBName:  20251109_191214.jpg
Size:  175.1 KBName:  20251027_124550.jpg
Size:  329.1 KBName:  20251018_174358.jpg
      This was truly the worst part of my whole life! I have never done bodywork and im not doing it again at least this amount .
      Jul 2026
      Az
      Attachment 220907Attachment 220908Attachment 220909Attachment 220910Attachment 220911Name:  20251117_155552.jpg
      Sprayed spi epoxy primer on her. I do realize I should have sealed the sheet metal before filler work but at this point im over it.
      Jul 2026
      Az
Size:  439.6 KBName:  20251116_164826.jpg
Size:  423.6 KBName:  20251117_144110.jpg
Size:  335.0 KBName:  20251117_214346.jpg
Size:  310.6 KBName:  20251116_173223.jpg
      Two coats and it laid down really good
      Jul 2026
      Az
Size:  396.0 KBName:  20260516_144239.jpg
Size:  308.7 KBName:  20260516_154614.jpg
Size:  340.5 KBName:  20260521_170318.jpg
Size:  312.4 KBName:  20260521_170332.jpg
Size:  390.3 KBName:  20260521_170556.jpg
Size:  388.5 KBName:  20260521_170349.jpg
      Got the moser housing, currie 3rd member, 4.11 gears, helical posi completed and put 2014 zl1 brakes on the rear calipers will be swapped out to ctsv calipers (there the same)
      Jul 2026
      Az
Size:  406.4 KBName:  20260519_153338.jpg
Size:  363.8 KBName:  20260430_164552.jpg
Size:  185.3 KBName:  20260425_105558.jpg
Size:  230.4 KBName:  20260425_083050.jpg
Size:  204.8 KBName:  20260424_223320.jpg
Size:  601.6 KBName:  20260424_223207.jpg
Size:  267.3 KBName:  20260424_193821.jpg
Size:  592.0 KBName:  20260424_175947.jpg
Size:  532.9 KBName:  20260519_124333.jpg
      Made a new rear harness. Added speaker wire and 12g fuel pump wire as the core all tefzel wire. Used the original plug but kept enough slack in case I want to change plugs.
      Jul 2026
      Az
      did some mock up and caliper needs to go rearward
      - - - Updated - - -
      is there a way to make the pictures normal like up and down not sideways?
