      Jun 2009
      From Wasilla, AK. Now portland, OR
      C6 bearing for mk60
      So what is the currant go to wheel bearing for a c5 / c6 hub for adding a mk60 abs system? I know it needs to be a version with an active speed sensor. Thanks
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
      Nov 2018
      Neat, had no idea this existed. Thanks.
      Did a little DuckFu on this, found these links:
      https://www.corvetteforum.com/forums...ndalone-4.html
      https://grassrootsmotorsports.com/fo.../261745/page3/
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Beach Park IL
      SKF BR930544 is the one you want for the MK60. (or Delta ABS or Bosch for that matter) You need the active sensor that these have and not the passive sensor that was present previous to 09. *09 was a weird year as the axle splines changed on some models so I just shop for the 10-13 to ensure that I get the 33 spline hubs.
      If not a track car you may be able to use any manufacturers 2010-2013 Corvette hubs but I only have experience with the SKF and MK60 swaps.
      The c7 bearings will also work but they have a separate speed sensor that you will have to mount and that can be difficult in most aftermarket uprights.
      Donny
