      Feb 2025
      Quick Performance Housing: Bolt RT 4‑Link to Stock Perches, Use RT Brackets
      Hey everyone, I’m working on a ’67 Mustang and planning a ridetech coil-over + 4‑link rear suspension setup.
      I’ve seen the kit gives two options:
      1. Use the stock leaf spring perches as the lower mounting point.
      2. Use the optional weld-on lower brackets that ridetech provides.
      which have you used ?which is the best way to go?Name:  IMG_0128.jpeg
      Feb 2013
      If you're starting with a bare housing, I would use the weld on brackets. It's cleaner with the U-bolts and less fasteners to tighten. The weld on bracket also takes up less room than the original style clamping plates so it also gives you more room in that area as well.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
