Results 1 to 13 of 13
Thread: 427 SBC, American Speed?
01-16-2006 #1
- Jan 2006
- 2
I'm looking to put a 427ci small block chevy with about 550-600hp into a early nova. The 427 from American Speed looks like a good set up. Anyone have any experience with American Speed, good or bad?
01-25-2006 #2I have never heard anything bad about them. Very reputable company from what I know. They supply all the engines for the British Ultima GTR sports cars (www.ultimasportscars.com). I would love to build one of those some day. I have also been looking into buying a 427 from American speed. They only sell long blocks or turn key engines. They will not sell you an engine that they cannot dyno test. I think that is a good thing. It is a tossup between them and Shafiroff racing for my engine. I like American speed's 427 combination better than Shafiroff's 434. Price is about the same. I just spoke to someone at American speed. The 427 I'm interested in makes 550 hp @5800 rpm and 590 lbs @ 4100. It has 10:1 and a hydraulic roller. To top it off, aprox. 14 inches of vacuum at idle. Sounds like a great street engine.
-Andy
01-25-2006 #3
- Apr 2002
- north carolina
- 147
steve - check your pm's
01-25-2006 #4
Banned
- Aug 2003
- Orlando, FL
- 8,745
I have great sucsess with Bill Mitchell motors. I have two 427 / 550HP motors in my camp right now. There are other advantages to Bill Mitchell besides the fact Bill Mitchell is the manufacturer of the raw goods. Also, Bill Mitchell motors come compete with carb, distirutor, wires, etc, ready to run. The American Speed motor will require at least another $1000 in options to be as complete as the Bill Mithcell motor.
I am a Bill Mitchell dealer, so if you need something let me know.
And BTW, the complete Bill Mitchell motor is $200 cheaper then the American Speed long block. It looks like a American Speed 550HP motor will run about $11,000, vs Bill Mitchell at $9800.
01-25-2006 #5
- Jan 2006
- 2
The American Speed did sound like a nice set up. I've been looking at four different places so far. Speed, Mitchell, Shafiroff, and Nelson. All seem to be pretty reputable. I want it to be a 427 though, just like the history of that number with Chevy engines.
Originally Posted by streetk14
01-25-2006 #6
- Aug 2004
- 830
nothing bad to say about the company but a thing to watch out with these big inch small blocks is rod to stroke ratio, many of them use small rods which isn’t good for any thing in a high performance engine as they hurt volumetric efficiency, and a lot of them that use a Chevrolet block with the stock deck height have long rods have pistons with a very low compression height that means the wrist pin is located very high on the skirt of the piston and this gives you very little room for things like rings, this gives you very little room between the compression ring and the deck of the piston, this area takes the most beating out of any other part of the piston if you plan to run any kind of nitrous or forced induction. on an engine that will see a lot of spray or forced induction its important to have a lot of metal in this area. if you plan to run it any other way then naturally aspirated then do your research and make sure it can hold up. other wise don’t worry about it. just wanted to share some of my knowledge to help you with your purchase.
Rob M.
01-26-2006 #7Most of these engines use 6" rods to help offset the stroke. I agree with the compression height thing. I spoke to Shafiroff about building me a 434 (using a motown block) that could be used with a blower. To get the compression where I wanted required a very low compression height. Not a good thing when you are looking at 750+ hp. I decided to go with a N/A motor for simplicity resons. Both Shafiroff and American Speed know their stuff. Their engines are designed to be durable street engines. Shafiroff even has a standard 24,000 mile warranty. I've talked to the guys at Shafiroff several times, and they are always very friendly and helpful. I can't really say the same about American Speed. But that doesn't mean they don't build great engines. The guy on the phone at American Speed always sounds pissed off for some reason.
Originally Posted by RobM
01-26-2006 #8I received quite a bit of the runaround when I wanted Shafiroff to build a 540 BBC for a blown application. When I gave the (to remain unamed) person the specs, I heard nothing for days. When I called back, I was told to ask Dart for head info, Comp Cams for cam info, etc. I thought SSRE was being paid to do that. I then called Steve Morris, but was afraid after reading in Hot Rod, that at the Pump Gas drags they blew the motor up 3 seconds into the first run. Oops. A car buddy then said to call Nelson Racing Engines and I have had no regrets since. Have not dealt with American Speed other than a phone inquiry. Just so more info for you for what it's worth.
Project "Freebird"
01-26-2006 #9
Banned
- Aug 2003
- Orlando, FL
- 8,745
Well, tomorrow i'll be beating on a 564Hp 427CI Mithell motor in a awesome 55 we are just finishing. I'll let you know the results
01-26-2006 #10
Originally Posted by ProdigyCustoms
Let me know what you think of it. What are the specs on that motor? How much torque does it put out?
01-28-2006 #11
