      Oct 2024
      G-Body Rear Brake Options
      I see a bunch of different rear disk brake kits that all look very similar but some of them are $400 and some of them are $1000. What's the best bang for the buck kit that has good balance with C5 fronts? Or would it be a good choice to just put good shoes and drums on the stock rears?
      I've used C5 front disc's and 1997 Camaro and 2002 Camaro rear discs on a number of swaps.
      I prefer the 2002 Camaro since it has the e-brake configured as small drum brake inside the rotor. I use a Wilwood adjustable prop valve.
      My go to guy for brake advice Tobin at KORE3>com
      Apr 2016
      What rear is in your G body? Ls1 camaro(98-2002) rear brakes are a good option if you can find the parts, C5 rear brakes would be another good choice
      Oct 2024
      Quote Originally Posted by Jk918 View Post
      Just a stock 7.5.
      Do LS1 rears use the stock parking brake cables?
      On my hot rod projects I use the Lokar e-brake universal cables. They come with a bracket that slips right over the 2002 Camaro e-brake "arm".
