      Jul 2015
      South Bay Area, CA
      1969 Camaro Project For Sale
      1969 Camaro Project For Sale - SOLD
      -Brand new LS9 with speedtech dry sump oil pan
      -Moroso remote mount oil filter
      -Custom Peterson dry sump oil tank with added capacity, fluid sight glass, & temp. gauge
      -GM Engine harness and ECM
      -Brand new LS9 acc. drive (discontinued)
      -Concept 1 low mount AC compressor
      -Kong 2650 blower (used) 2.35 pulley
      -Custom C&R supercharger bricks and spacer (40% larger than stock) or Kong Bricks (stock height)
      -XCFM intercooler brick inlets
      -DSE stainless 1 7/8” headers (wrapped in black)
      -DSE motor mounts
      -Autorad 850+ HP radiator, oil cooler, heat exchanger, condenser, fan package
      - Black Rick’s Stainless tank w/ 3 525 pumps (e85 capable 1000+ HP)
      -FORE fuel filter
      -Fragola black PTFE fuel lines
      -DSX fuel rails
      -T56 magnum trans
      -QuickTime Bellhousing (scatter shield)
      -DSE Subframe with custom tie down hooks & fresh Powdercoat
      - DSE Quadralink rear suspension
      -DSE Quadralink lower link reinforcement kit
      -9 inch rear axle w/ locker and teflon coated nascar 3rd member, Dutchman axles, 3.89 ratio
      -DSE mini tubs
      -DSE Weld-in subframe connectors
      -DSE transmission crossmember (discontinued)
      -Weld-in fuel pump access plate
      -DSE half-height body mounts
      - Bowler weld-in trans tunnel
      -Hurst white lightning shifter
      -Custom 8 pt. Roll cage with door swing-outs, removable downtubes and removable harness bar
      -rear seat delete/firewall & dusold carbon fiber rear seat delete
      -smoothed firewall
      -raptor lined bottom of car
      -wilwood 14” brakes front and rear
      -Wilwood brake and clutch pedal
      -wilwood brake and clutch master cylinders w/ proportioning valve
      -IDIDIT tilt steering column
      -NRG removable steering wheel adapter
      -Sparco steering wheel
      -Eddie motorsports black billet tail lights
      -Fesler billet Trunk Hinges (black)
      -Ring brothers billet air frame hood hinges (black)
      -New front and rear windshields
      -Anvil carbon fiber hood with carbon fiber heat extractors
      -Anvil carbon fiber fenders (1.5” wider than stock)
      -Anvil carbon fiber front Valence, splitter, header panel, cowl panel, rear deck lid, rear spoiler, dash, A-Pillars
      -Anvil fiberglass front inner fenders and fender extensions
      -Forgeline 18x10.5 & 18x12.5 black lip w/ graphite grey centers and barrels
      -315/30/18 & 335/30/18 BFG Rival S tires
      -Anvil carbon fiber fenders braces
      -Anvil carbon fiber 2nd gen side mirrors
      -Anvil carbon fiber rear view mirror
      -Anvil carbon fiber door handles
      - shaved drip rails
      The bad:
      - One of the 2 recaro seats caught fire while welding
      -Started widening the quarter panels to match front fenders, haven’t finished and still needs work OR quarter panel replacement
      Needs:
      -Clutch (sold the stock LS9)
      -Injectors (Sold stock LS9)
      -Gauges
      -Interior (door panels, headliner, etc.)
      -Drive shaft
      -Body & Paint
      -Body harness
      -Door glass
      -Fesler flush glass (optional)
      -Headlights
      I know there is other misc. stuff I have and misc. stuff I’m missing.
      Gilroy, CA
      SOLD
Size:  456.6 KBName:  IMG_3962.jpg
      Nov 2020
      Paso Robles California
      Beautiful build !!! Looks to be priced for a quick sale. Best of luck with it !
      Jason
      Jul 2015
      South Bay Area, CA
      Quote Originally Posted by Jason_Aschle View Post
      Jason
      Thanks!
