      Portland OR
      69 Camaro Project, you finish it
      Item Location (City/State): Newberg, OR
      Price: $110K OBO
      Description: 69 Camaro Pro-touring build, running, needs finishing
      Seller's agent:
      John Campbell at Campbell Motorsports and Appraisal. Please contact John for offers and sale information.
      Background:
      This car has appeared on "that other site" before as a featured car. Please see that link for details of the original build, completed in 2010. Back then, the car was a state of the art build, and I enjoyed the heck out of it for six years, running extensively in HPDE on the West Coast. Late in 2016 I blew the engine on the back straight at Thunderhill, and decided to upgrade the car to the latest tech, with Mark Stielow's Hellfire build as my model. Over the next year or so we got it most of the way completed, then life intervened. Between job, family health issues, and a new obsession with amateur road racing, the build got put on the back burner and stayed there. At this point, I'm unlikely to ever get it done, so it falls to one of you to get it there. Make it into the multi purpose street/track/OUSCI machine it was intended to be.
      Engine
      LT4 650hp/650tq dry sump crate engine with ECU & harness, circa 2016 w/stock internals (zero miles on engine)
      Drive Junky front accessory drive system
      Trunk-mounted 12-quart dry sump, a la Texaco Camaro
      Custom C&R cooling stack w/radiator/intercooler/AC condenser, trans cooler & Cadillac CTS-V fan (like Stielow Hellfire car)
      Lingenfelter pwm fan controller
      Included but not installed:
      Katech 720 hp kit: Larger crank pulley, DOD delete lifter set, DOD delete valley lifter plate, cylinder head & exhaust gaskets
      PCV catch tank system
      Custom coolant overflow reservoir/washer reservoir
      Moroso auxillary intercooler reservoir
      Upgraded aftermarket intercooler pump
      GM crate engine fuel pump controller
      Ricks Tanks stainless fuel tank with corner pickups & 6th gen Camaro ZL1 fuel pump
      (fuel tank has small dent on the bottom)
      Drivetrain
      D&D T56 transmission, .80 /.62 ratio 5th and 6th gears
      Transmission cooling system with pump, hoses & cooler in radiator (also cools diff)
      Detroit Speed (DSE) 9- inch rear end housing modified for internal oil cooler (like Stielow Hellfire car), housing ends for C6 ZR1 bearings
      Aluminum 9” center section with 3.40 gears, micro polished and run-in by C&R
      Centerforce dual disc clutch
      Quicktime bellhousing
      Aluminum driveshaft
      Suspension
      DSE Hydroformed front subframe & full suspension kit w/C6 ZR1 wheel bearings
      DSE Quadralink rear suspension kit with track poly bushings
      DSC/ridetech Instinct electronic shocks, fully programmable damping curves, switchable programs
      Body/Exterior
      All sheet metal is original except AMD tail panel
      Anvil Auto carbon fiber fenders, hood, upper & lower valances and spoiler
      (Anvil fenders are seconds; small visible blemish on the RF fender)
      Anvil carbon fiber inner fender panels with custom mods for tire clearance
      Steel body panels and hood are painted 2008 Dodge Challenger Hemi Orange
      LED headlights with integrated turn signals & running lights
      Digi tails LED taillights
      Trackspec hood vents
      DSE rear mini-tubs
      New standard style (non-RS) grill & headlight trim (included but not installed)
      DSE Core support closeout panel (included but not installed)
      DSE delay windshield wiper kit
      LOF/Pilkington door, quarter & rear glass
      DSE battery relocation kit
      Brakes
      Front and rear AP Radi-Cal competition racing brake kit for C6 Corvette, from Essex parts
      6 piston front, 4 piston rear, floating rotors (zero miles on brakes)
      DSE C6 Corvette booster and master cylinder
      Bosch motorsports M4 Clubsport ABS system
      Wheels and tires
      CCW C140 Monoblock wheels, 18x11 front (25mm offset), 18x12 rear (44mm offset) (new)
      Hooser R1 slicks, 315/30 front, 335/30 rear (old & should be replaced)
      Exhaust
      Ultimate Headers long tube headers
      Hooker 3-inch exhaust with resonators, for DSE rear suspension & Rick’s tank
      Interior
      Custom TMI door and quarter panels with orange stitching (new, not installed)
      Custom TMI console with orange stitching (new, not installed)
      TMI carpet kit (new, not installed)
      MPI Steering wheel with orange stitching (new, not installed)
      Recaro Sportster bucket seats (new)
      Flaming River tilt steering column
      DSE steel dash insert, modified to accommodate Motec cluster
      Motec C127 digital dash display cluster, custom programmed
      (License for Motec dash creator software included)
      Vintage Air A/C (controller seems to be inoperable right now)
      Full interior roll cage (with removable door bars, dash cross-bar, rear cross bar & front hoop)
      Mito Corp rear-view mirror with compass & outside temperature
      AAW classic upgrade wiring kit (some wires have been left unterminated for future use)
      Battery kill-switch (mounted in trunk)
      New optima battery
      Items that still need to be completed (partial list):
      ECU/engine dyno tune
      All dash cluster wiring to sensors (wiring diagram provided)
      Install door panels, console & steering wheel
      Front body panels fitment/adjustments and grill install
      Shock controller programming
      ABS controller verification
      Paint or wrap (existing paint has some chips)
      New tires
Size:  483.5 KBName:  1000002790.jpg
Size:  664.1 KBName:  1000002792.jpg
Size:  325.2 KBName:  1000002783.jpg
Size:  427.0 KBName:  1000002784.jpg
      Orange 69 Camaro RS, DSE, Baer, LS7/T56, driven!
