    Results 1 to 20 of 23
      Project Mini-ULTM8Z
      So my daughters got me this Camaro model for Christmas. They spent quite a bit of time trying to find one with a full bumper at that (I was actually impressed they were aware of the difference). I actually haven't built a car model like this in ~45 years... lol. Needless to say it's going to take me back to my childhood too.
      So I figured I'm going to do it justice and open up a project thread on it. The plan is to make a mini-version of my Camaro, so I'm also ordering this 1996 Collectors Edition Vette model in order to get the wheels and tires, the engine (since the LT1's are extremely similar in appearance to my Miniram'd 383), the 4 wheel disc brakes, etc...
      1971 Camaro
      Started doing some preliminary work today, mostly painting and stuff.
      I have the correct colors to match my Camaro... the PB3 1998 Dodge Intense Blue as well as the factory 1971 Dark Saddle for the interior.
      1971 Camaro
      Still need to get some gloss clear coat, but so far the body came out really good IMO...
      Door panels and dash... man, it was tough trying to get the silver detail on the gauge rims, but for the scale of this car, not bad IMO...
      1971 Camaro
      Overall what I want to do is have this car on display on the dashboard at car shows.
      I've seen that kind of thing before and it's kinda neat...
      I'll have to figure out how to prop the hood up since the scale engines in these models are actually quite detailed.
      1971 Camaro
      Finished the bright work. A little black primer gives the look of the door window sweep. Lol...
      I'm literally working under a magnifying glass with this thing..
      1971 Camaro
      A little more progress today. Getting to the point where I'll need to pause until the Corvette model comes in so I can see how I"m going to combine the two.
      1971 Camaro
      Jul 2019
      Ohio
      Cool project. Did that paint work well on the plastic body?
      Fun!!!
      Quote Originally Posted by srode View Post
      Amazingly well. So much so I can put masking tape on it and it doesn't peel or degrade in any way.
      1971 Camaro
      Love the Intense Blue!
      Jul 2019
      Ohio
      where did you get the blue paint? I have a 69 Camaro model that's been sitting in the office for probably 10 years I might finally put together.
      I've had the can for several years. I got it from one of the local parts stores.... I believe Pep Boys.
      1971 Camaro
      Corvette model arrived. Scale is correct!
      Just a quick mock up...
      1971 Camaro
      Parts seem to intermix pretty well. They did their math right on the scale at least. Some minor mods and it should be good.
      My actual engine for reference. I may use a piece of black wire to form a cold air tube... lol.
      The model is LT1 so there will be some differences, but most people mistake my Miniram SBC for a LT1 anyway.
      1971 Camaro
      Lol... cold air tube
      1971 Camaro
      Figured I'd make a set of spark plug wires to try to convert this LT1 into a SBC...
      Pulled some strands of copper wire out of some 12 awg wire. Soldered them together where they go on the cap. Then found a piece of plastic to represent the distributor cap.
      - - - Updated - - -
      Grill...
      1971 Camaro
      Re-purposed the starter motor out of the '71 kit into a Sanden A/C compressor... lol... then grafted a portion of '71 belts/pulleys on.
      1971 Camaro
      Getting close finishing! Engine is in... had to modify the oil pan and the transmission tail housing to get it to fit... The HEI distributor and plug wires came out pretty cool too I think.
      I'm not going to pay that much attention to the under carriage. The model will spend it's entire life right-side up.
      - - - Updated - - -
      I decided to run with the Corvette steering wheel. Neither is a match for my Momo wheel, but the Vette looks more updated...
      - - - Updated - - -
      The '71 fan shroud without the fan is a pretty good approximation of my Taurus electric fan
      - - - Updated - - -
      Glass is in and some detail on the master cylinder and booster.
      1971 Camaro
      Body on chassis finally...
      I had to break the alternator and A/C off and lower them a bit as they were hitting the hood.... funny that wasn't the case on my actual Camaro... hmmmm.....
      I'm going to have to offset the wheel centerlines from the axles a bit in order to set the ride height. Also, as in real life, the offset on the Vette wheels is too deep... lol... I'll need some 1/25 scale wheel spacers.
      1971 Camaro
      thinking about hood how to prop the hood up for display. I'll probably use some paper clips.
      But I was thinking I could print out some 1/25 scale pictures of hood hinges, cut them out and then glue them to the paper clips...
      1971 Camaro
