      Jul 2013
      N. Scottsdale
      Holley 2nd Gen engine mount height
      I installed a LQ4 in a 79 Firebird using the Holley late second gen (75-81) engine mounts together with their mount cages and poly inserts, and was surprised to see I had so much room, at least 1.75", between the crossmember and the oil pan (Holley 302-3). I didn't really think about it until I installed the driveshaft and checked driveline angles...I ended up having to shim the tail of the transmission (TKX) up quite a bit to get things to work out, so much so I had to cut the floor in a small area just in front of the shifter because it was making contact. Not a big deal, but wondering if those Holley mounts set the engine too high or whether that height is normal? This is my first LS swap, for I've always run Pontiac engines in my Pontiacs.
      Beach Park IL
      What about the bottom of the pan. About flush with the bottom of the crossmember?
      Donny
      Jul 2013
      N. Scottsdale
      The bottom of the pan is around .75" above the bottom of the crossmember.
      Beach Park IL
      Weird. My 302-1 is about flush with the bottom using all Holley mounts. That pan is a bit deeper than the -3 or -2 but not 3/4" of an inch. I did use rubber mounts, not urethane. Might be the difference between early and late subframes.
      Looking at your headers, I'm not sure I would want the engine lower. I really don't see anything wrong with your set up as is.
      Regarding driveline angles, I am actually running pinion down to get my working angles in check. That's with a small spacer at the trans mount, I don't remember what size.
      Donny
      Jul 2013
      N. Scottsdale
      Thanks for chiming in...helpful in trying to figure out what's going on. IIRC, the bottom most part of the -1 pan is about .25" deeper than the -3, so that doesn't account for the entire difference. I bought the Holley mounts for the later second gen subframe, but I think the only difference is that the earlier mounts come with a template for holes that need to be drilled in the crossmember...may be wrong about this, but that was my understanding from Holley tech support.
      You are correct that with the headers we're running, the engine can't really be any lower. For some reason the driver side header is .5 lower than the passenger side even though the engine is perfectly level side to side. I had considered switching to shorties for added ground clearance, but it's a father and son project, and son really wants long tubes, and it's his car...we'll see how long they last!
      We ended up removing a 6"x7" section of floor right in front of the shifter hole and made a slightly raised cover so that we could shim the tail of the transmission up 1.25" without any chance of contact. We can dial in really good driveline angles with a 1" shim, but we wanted extra room in case we find that we have to move things around a bit to address any driveline issues that crop up.
