      Dec 2008
      Blanchard, Ok
      Transmission / Torque Converter Noise
      Anytime my car goes into gear I hear a chattering noise. It doesn't make the noise at idle, and it increases with rpm, then goes away around 2500. I've been told it sounds like a loose torque converter so I got underneath and checked the torque converter bolts. They were all tight. Anyone have any idea what it could be?
      https://www.youtube.com/shorts/qhgtorHUG7Y
      Brad Bickers
      '67 Camaro, Blueprint 383/ 700r4
      Dec 2022
      Could be a cracked flex-plate making noise. Cracks around the bolts to the crankshaft
      Beach Park IL
      Any evidence of rubbing when you had the dust cover off?
      Donny
      Fairbanks, Alaska
      Converter
      Mine did that, was a Turbo 400 and turned out to be a broken stall converter. I waited too long to drop the trans and it wound up going through a lock up on the way home.
