08-19-2024 #1
- Jun 2018
- SW Florida
- 48
A Body LS Front Brake Conversion Kit
Everything needed to convert A body front brakes to 1997-2002 Camaro 12"-disc brakes. Calipers were professionally rebuilt using all new parts, and powder coated red. EBC red stuff brake pads. Kore3 caliper brackets and hardware, Power Stop drilled and slotted 12" rotors, and Kore3 modified iron wheel hubs with longer ARP wheel studs. Also included are the mounting hardware. System has about ~5500 cruising miles. I can throw in the original "farm fresh" disc brake spindles and steering arms. You will probably need at least 17" wheels to use these, but they might fit under 16" wheels, depending on the wheel. I had to go to larger brakes when I converted to Speedtech tall spindles. $250 and you pay to box and ship
