    Results 1 to 1 of 1
      1968 Camaro Project FS
      Selling car to fund another project.1968 CamaroNo rustHave titleBody:New Dynacorn Sheet metalFront RS fendersHeaderValance2" Steel cowl hoodDeck lidRear spoilerInner fenders are powder coated hammer tone greyNot mini tubbedHad 6 pt roll bar but the door bars have been removed Have all the glassBillet hood hinges blackSuspension: All new Front:BMR Upper and lower control armsBMR Sway barCCP C5 Spindles w/ C6 hubs with ARP studsViking Dbl Adj coil oversFront spindles and subframe powder coated hammertone grey to match BMR piecesCCP Steering boxRear: All newBMR Torque arm and Watts link setupGM 12 Bolt w/ 3.73, Eaton Posi, Strange CoverViking Dbl Adj coil oversBMR Subframe connectorsBMR Trans mount for 4L80 Brakes:No front brakesWilwood Black Master CylinderWilwood Prop Valve kitWilwood Rear Disc Kit NIB not installedWilwood Ebrake cable kitInterior:Complete Flatliners barrier/insulation kitNew dash padNew Ididit Prolite column in blackRBZ Billet steering wheelNew steering column bracketNew brake pedal assmMisc:New Champion Aluminum Radiator with twin 16" Spal fans and shroudBare LS3 blockBare 823 Heads4L80 Bare housingHolley LS MountsJegs Oil PanCar is currently located in Houston Tx at the body shop. Would consider trades for Can-am Defender$20k OBO713-253-0229
