Results 1 to 10 of 10
Thread: Hydroboost Help
- Feb 2019
- 25
Hydroboost Help
Does anyone have experience with hydroboost on a 69 Camaro? I have P/S with KRC Type 2 HP pump and Concept One dual return reservoir, new steering box, Wilwood at all 4 corners including MC with new P/S and brake lines. SS lines running from box to HB to pump.The brakes have been bled. I am going through the P/S and HB bleeding process. When I push on the brake pedal, it pulses and pushes back on the first push. Then is feels pretty steady except I can see the pedal has a slight slow return. If you hold the pedal down at idle you can hear a slight whine. When you turn the steering wheel to lock you can hear the slight whine and see the HP line from pump to HB jump a little. The fluid is no longer going down in the reservoir and is steady. I've never had HB and don't know what's normal and what's not. I don't want to drop car off of stands to realize I don't have brakes. I have yet to set prop valve on MC. All tests were at engine idle.
