    Thread: TKX crossmember
      May 2011
      Sioux Falls SD
      TKX crossmember
      How would you guys go about eliminating these spacers?
      The crossmember is from the summit frame brace kit. This is on my 66 GTO.
      Thanks!
      Nov 2014
      is there a rubber trans mount installed? if not, that would displace the outer spacers
      Sep 2022
      Energy suspension PN 3.1158G is what I used on my 68 GTO with G Force x member and TKX.
      They also have a taller version
      Oct 2008
      Toronto, Canada
      May 2011
      Sioux Falls SD
      American Powertrain sends a composite type of mount to use. That’s what is on there now.
      Thanks for the replies!
      Hildebran, NC
      I would space the trans mount up and have the crossmember sit flat to the frame pieces. Only 1 spacer vs 2.
      If you can fab, another option is to cut the top plates off the crossmember and reposition them lower. That is probably the best solution.
      Jul 2023
      You need a trans mount between the tailshaft housing and the crossmember. That will allow you to ditch the outer spacers where the crossmember mates to the frame.
      Without a trans mount, there is too much twist between motor mounts and chassis flex. I seen guys break the tailshaft housing due to flex on hard launch.
