    Results 1 to 10 of 10
      Mar 2024
      Aggressive wheel specs for 1979 Trans am
      hello all,
      anyone installed 18 front and rear or 18 + 19 wheels on 2 gen Firebird with coilovers?
      I'm planning to install 18 with front 255 45 18 + 295 40 19 on 10j and 11j wheels. Front coilovers + rear stock leaf springs
      Name:  JSD07178 — копия.jpg
      I've run coilovers with a 18x8f 255/40/18 and 18x10r 295/40/18 with no other modifications on my car.
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Mar 2024
      Quote Originally Posted by OLDFLM View Post
      do you have backspace data for wheels?
      my wheels are 8j with 3" backspace front and 10j 3" backspace rear.
      did you use lowering leaf springs on back?
      I've ordered QA1 550 lbs single adjustment for front and currently keep stock rears, I plan to use same tire sizes 255/40/18 and 295/40/18 but wider wheels like 9,5 front and 11 rear for more lip size.
      also plan to install 6 piston 355mm rotors new brakes, but keep drum brakes for rear, will it work normally?
      Mountain Springs, Texas
      Quote Originally Posted by DM427 View Post
      That is nowhere near enough backspacing unless you have a sky high ride height…
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Aug 2005
      Hamilton, NJ
      Why do you need a 10" wheel with a 255/45/18? That size calls for an 8-9.5" wheel. Or am I reading this wrong?
      Scott from NJ.
      Vent Windows Forever! ...
      Cornettsville, ky
      Quote Originally Posted by BonzoHansen View Post
      i run my 72 buick with 8.5 wide wheels and 255 wheels. fit fine.
      Search for SW's Trans Am
      8x8f 4.5bs 255/40/18
      18x10r 5.75bs 295/40/18
      Search this forum for "Streetking" to see pics of his red 73 Trans Am.
      He's running a 295/35/18 on the rear but I like a little more sidewall so I went with a 295/40/18.
      I think the taller tire fills the wheelwell nicely on a muscle car.
      There are a lot of tire fitment threads on here if you search...
      https://www.pro-touring.com/threads/...ght=streetking
      Mar 2024
      thank you!
      do you have photos of your car with 255/40 + 295/40 set up?
      Search the forum...
Size:  171.5 KBName:  Powerblock001.jpg
Size:  172.7 KBName:  sema12.jpg
Size:  116.2 KBName:  2009 11-05 Sema 839.JPG
Size:  367.3 KBName:  2009 11-05 Sema 829.JPG
Size:  311.1 KBName:  sema7.jpg
      Mar 2024
      thank you, is there a video of your car in YouTube?
      front 255/40 18 or 255/45 18?
      - - - Updated - - -
      did you lower rear axles with leaf springs? or you have coilovers?
    Tags for this Thread
