      Jan 2024
      Formula 43 wheel help
      I bought a set of formula 43 rad10 wheels. I know they are no longer around. But what i need. Is the tourque specs for the 30 bolts that hold the 3 piece wheels together. I知 gonna be refinishing them so they have to come apart. If anyone can help me I would appreciate it thanks
      Beach Park IL
      What size is the hardware?
      Donny
      Jan 2024
      I値l check tomorrow and get back to you what size they are
      Austin, Tx
      I would expect you could use the same torque specs I used on my Forgelines, as I'll assume the hardware is going to be the same size. I was told to use 26 ft-lb for any bolt/nut fasteners and 25 ft-lb for any blind bolts (which is what it appears your wheels use). I was also told that I could use anti-seize on the bolts (although I didn't), but not to use Loctite.
      Bryan (a.k.a. Carbuff)
      70 Camaro RS Hunk'o'Metal - Previous Project
      71 Firebird Project T.O.W. - New Project
      Beach Park IL
      And that is probably correct but I wasn't sure what size the hardware is.
      Donny
      Jan 2024
      Here痴 a pic of the bolts that I知 talking about Thanks for the help
      Beach Park IL
      For those of us that went to the moon, that's 1/4" if you torque that to 25 ftlbs you will have a bad time.
      12 ft lbs if they are grade 8 or better.
      Donny
