    Results 1 to 1 of 1
      Dec 2013
      LT4 Rocker arm issues
      I'm putting together a gen V lt4 for my 56' GMC.
      I did a DOD delete on it and used LS7 lifters, stock 7.850" pushrod length BTR rods, and Texas Speed LT4 adjustable rocker arms( i got a great deal on them..didn't look for these specifically fyi)
      Anyway, I went to bolt the rockers on and noticed they open the valve probably .020" when tightened down. (yes, on base circle)
      So now i'm scratching my head. Got an adjustable push rod and tried to come up with the proper length.
      I basically took the rod and set it up for zero lash and then added .070 to that measurement and came up with a 7.70" rod.
      Did I go about this right? and is it safe to use the same rod on all valves even when factoring in the lash caps on the intake valves?
      Sorry for the long post.
      Thanks for any helpName:  thumbnail (1).jpg
