    Results 1 to 13 of 13
      Apr 2017
      TN
      3D printing dash bezel
      Anyone know of a company that has a 3D printer big enough to make a custom dash bezel for my 65 Chevelle? I'm looking to keep the gauges set up like stock but eliminate the radio and A/C vent. Not a fan of the radio delete plates I've seen. Something like the attached picture, except not billet aluminum and not $4500 lol.Name:  Screenshot_20231117_173252_Samsung Internet.jpg
      I have been working with Reversion Raceworks for some parts on my GTO:
      https://reversionraceworks.com/
      Usually what is done with large parts is that they are printed in pieces and bonded together into the final part.
      Apr 2017
      TN
      Awesome! Thank you Andrew!
      Nov 2014
      check Sew It Seams Custom Upholstery in New Braunfels TX. I toured the shop and they have a scanner and several printers and were working on custom parts for an F100 SEMA build.
      They will do a custom interior for my '57 custom truck in the near future
      Feb 2019
      Kankakee IL
      Apr 2017
      TN
      Quote Originally Posted by btmatt View Post
      Thank you!
      - - - Updated - - -
      Thanks, that's an option if I can't get exactly what I want.
      Apr 2007
      New Jersey
      Classic Dash has a page for blank dash panels. If they have one for your 65 you can cut the holes yourself and get the layout that you prefer.
      Doug L.
      68 RS/SS Conv. LSA/T56.
      67 RS Coupe LS2/T56 named "NutKse"
      Nov 2010
      Ventura County CA
      I used D3D printing services in Tujunga CA to print my gauge cluster insert out of ABS. Mine measures about 18" wide and was printed with the front curved face down on the bed. I designed this myself. Looking at the size of yours, you may be better off using two pieces and joined by pinning and gluing, then hide the seam with body filler and sanding.
      Here you can see the layer lines before filler and sanding. They are a bit exaggerated because the face is curved. If yours is flat, the layer lines will not be nearly as noticeable or take as long to sand smooth.
      I used several coats of Bondo sprayable filler primer with hand sanding in between by an assortment of sanding sticks (made by gluing sandpaper to popsicle sticks) and sponges to clean up the layer lines. This took quite a bit of work and you might consider using vapor smoothing or another method of filling if you want things to be smooth.
      I finished my insert using SEM black interior dye spray (which I also used on the original dash piece) and Molotov chrome pen with a Alclad Aqua Gloss sealer for the 'chrome" edging.
      Getting the design right took a lot of time in CAD and I printed 2D templates from my CAD model to check fitment before I finally sent it for printing. It's not perfect but it's unique and was a really rewarding project. I hope you have a good experience!
      Apr 2017
      TN
      Quote Originally Posted by TheBandit View Post
      That came out great! Appreciate the detailed response!
      - - - Updated - - -
      Quote Originally Posted by thedugan View Post
      Thanks, last I checked with them they no longer offer the blank for a 65.
      - - - Updated - - -
      Great, thanks. I'll check them out.
      Dec 2025
      I would love to get that file to 3d print one for my ventura if you would be willing to share it thanks
      Feb 2013
      South Carolina
      Trimech Solutions is our CAD vendor but they also sell 3D printers and print to order. You may have a local office near you.
      Apr 2026
      $4500 billet aluminum dash bezel
      Hi Cheveezy who makes this $4500 billet aluminum dash bezel you posted back in Dec 2023? Could you please let me know the vendor? Thanks.
      Apr 2017
      TN
      Michigan Machine Worx was the vendor.
