      Dec 2023
      Boston
      engine and trans
      Is it necessary to drain the oil and trans fluid when pulling an engine and trans?
      Apr 2016
      Its not nessary but often make a mess if you don't. Likely loose the transmission fluid out the tailshaft if you don't plug it
      Dec 2021
      HAMPTON VIRGINIA
      oil would be fine to leave in but you will definitely lose fluid from the tail shaft. If you can keep the engine and trans pretty level you can usually get by with just a sandwich bag and some zip ties around the tail shaft to avoid a huge mess
