      Jul 2008
      Anyway to determine spring rate without scales?
      Need to figure out what rear spring rate to go with, I can buy and swap springs but want to hopefully get close without a lot of purchasing involved.
      Don't know of anyone in my area with scales besides the platform scale at the dragstrip, entry/exit is sloped so I don't think I could get accurate rear weight by parking just rear tires on it?
      Just installed coilovers up front and am now realizing how soft the rear is w/ factory moog springs. I plan on getting adjustable shocks on the rear and aftermarket springs. Have rear coil spring setup and setting height is pretty simple, plus I'm running 3" exhaust, don't think I would have enough room for coilovers.
      *Jeff*
      Mountain Springs, Texas
      Can’t answer your question but I used UMI rear springs on my 64 A body with good results. I did end up raising the front on this car.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2008
      Thank you Don for the reply, pretty much the route I'll take. My front springs were sagging from beating on them, looked like yours, reason I opted for the coil overs, slapping myself for waiting so long.
      https://flic.kr/p/2njnZ6d
      *Jeff*
      Beach Park IL
      Do you know the rate of the factory springs?
      Donny
      Jul 2008
      The fronts were moog 6200, 290lbs/in
      The rears are moog 6197, 138lbs/in
      The front replacements are QA1 double adjustable with 450lbs/in springs. Looking to keep it from being a kidney beater but also be able to turn if that makes sense? Did an iron LQ4/t56 swap but set it back to the firewall to help with overall weight distribution. Doesn't help with the fuel tank out at the rear bumper though.
      *Jeff*
      Beach Park IL
      Approximately another 75 pounds in wheel rate in the front. 175-200 would be a decent stab at the rears......probably 175 if you want to consider the spring being behind the axle instead of in front/on top.
      Donny
      Jul 2008
      Thank you, I greatly appreciate the advice!
      *Jeff*
