      Aug 2022
      Fuel System Setup - Need input
      Hey all,
      I have a cammed SBE 5.3 going in a 69' chevelle. Going with Tanks inc. Fuel Tank with the GPA-9 Hellcat fuel pump and floatless sending unit. The fuel lines will be -8AN from Tank to Fuel Rails and back. Coming out of the tank is a 1/4" NPT fitting with a 1/4" NPT to -8AN Adapter (I contacted Tanks inc and they said that the fitting coming out of the fuel pump is 5/16" ID and haven't found the need to increase the size of the 1/4" NPT, which is fair. If it works, it works.). The car will be boosted and I'll be using FIC 1000's.All of this comes out to around $800. Not bad for an EFI setup that'll support high hp. Before I pull the trigger on this are there any other recommendations on a fuel tank setup?
      Power Goals are 600ish rwhp. I do have plans to pull the motor and swap out with a forged shortblock, hence the FIC 1000's. I figured I could use these injectors for the 600hp power goals currently and reuse them once I swap out the motor.
      Any input is greatly appreciated. Thanks
      Aug 2022
      San Jose, CA.
      I don't have any input on the fuel system. On the float less sender, be aware that it will read full for about the first 125 miles before beginning to drop. This is due to the recessed area the sender mounts in. I called Tanks inc recently and they confirmed the issue. Not a huge deal, just letting you know.
      Troy
      66 Chevelle LS3 T56
      Mountain Springs, Texas
      Spend some time on the vaporworx website then give Carl a call. He knows his stuff and is very helpful. You won’t find better advice imo.
      https://www.vaporworx.com/
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2014
      We made 530rwhp on 6.2 NA setup with Ricks tank and vaporworx modified LS3 bucket; -8 feed line. It has been flawless.
      Getting ready to install an LSA to go way north of 750rwhp and just bought Carl's Super ZL1 with pwm controller
      Apr 2016
      Don
      I would 2nd this, hard to beat a ricks restomod tank with a ZL1 fuel pump.
      Dec 2008
      Detroit
      Quote Originally Posted by Jk918 View Post
      I heard a while back they were going to stop carrying the Restomod tanks, so I bought one for each of my projects.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Aug 2022
      Quote Originally Posted by csouth View Post
      Just saw that they're having a 30% off sale on these tanks til' the Oct 1 I think
