    Results 1 to 12 of 12
      Oct 2009
      Speedtech preformed brake lines safe?
      Just wondering but the speedtech pre formed brake lines for their pro touring subframe have single flare ends with -3 fittings
      Isnt it true that single flared brakelines are not suitable for high pressure lines?
      Would a double flare work with AN fittings?
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Mountain Springs, Texas
      Looks like they use sleeves so I don’t see an issue.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2009
      Thanks Don, i may have to make a new line but my flaring tool doesnt have a die for single 37° flare. Would a double flare work with AN fittings?
      LS3
      Nov 2009
      the dirty mitten
      I used double flares for my AN lines, no issues. If you think about it the only thing it changes is the thickness of the flare itself. Of course the double flare is much safer and better. But just as far as the fittings are concerned, no issue there.
      Steve
      Quote Originally Posted by Sinnister69 View Post
      If it were me I’d use a proper tool and the sleeve especially if you are using stainless. If not I would at least use a conical seal with a double flare on AN fittings.
      Don
      Oct 2009
      Don
      I have the vice mounted flaring tool with the spring loaded lever and die blocks but i dont see a die for just a single flare.
      Step 1 is bubble flare and then step 2 is then formed to a double flare
      When i match the double flare against the female AN fitting it seems to seat well. And the sleeve sits well also. I just need verification i dont want my lines to blow while driving
      LS3
      I would use conical seals if I was using the wrong angle flare.
      https://www.summitracing.com/parts/ear-169103erl
      Oct 2009
      Description says it does do single flares i will have to see maybe skip the initial bubble flare and go straight to operation 2
      LS3
      Nov 2014
      AN fitting is 37' angle and conventional double flare is 45'
      I was always told not to mix...
      Oct 2009
      Quote Originally Posted by btmatt View Post
      I had to return my flaring tool since the turret was for 45° flares. An extra 37° turret would cost me over $100 so i just swapped out to the 37° system
      Thanks for all your help!
      LS3
      Sep 2017
      Boise, ID
      I have the Speedtech subframe for my Camaro and am debating on getting their kit or making my own lines. Whats your opinion on the kit? Worth it?
      Oct 2009
      Its a very nice kit comes with all you need. But if i were to do it again i would get some nicopp and make your own
      LS3
