    Results 1 to 20 of 26
      Warminster, PA
      Building a Poncho 400
      I'm planning on building a 400ci for my 79. Heres a simple list of the bolt ons and all:
      Holley Street Avenger 770cfm Carb
      Edelbrock Performer RPM Intake Manifold(Port Matched To Heads)
      KRE Aluminum Heads 85cc Ported for 290cfm @ 28" w/ 2.11
      Doug's D-Port Headers
      Pypes 3" Header Back X-Pipe Exhaust
      Comp Cams Cam:
      Cam Kit #: K-51-246-4
      RPM: 2,500 - 6,500
      INT Dur @ .050: 248
      EXH Dur @ .050: 248
      INT Lift w/ 1.5: .525
      EXH Lift w/ 1.5: .525
      LSA: 110*
      Comp Cams Alum 1.65 RR's
      Comp Cams Chromemoly Pushrods
      Sealed Power Forged Pistons(.040)
      Reconditioned Stock Rods & Crank
      This is basically the first step of the engine, other odds and ends of course. I'm also planning on eventually throwing on a procharger. How do you think this cam will work with the above, and then also when the super charger is on. Would you recommend a diff. cam when in throw on the s/c? I know ill have to get a blow through carb when i throw on the s/c, other than that what would you recommend? Thnx in advance.
      1979 Trans Am - In the big junkyard in the sky
      1980 Turbo Trans Am - In the big junkyard in the sky
      A journey of a thousand miles begins with a single BURNOUT!
