Thread: Seam sealer / primer question
The builder of my 67 C10 used body filler instead of seam sealer around the inside of the rain gutter. This eventually cracked & let some moisture in. I have cleaned that all out & removed the paint about 2" from the rain gutter. I may or may not use a rust treatment and wash before my next steps. My plan is to epoxy prime & then seam seal this area. I would like to then spray a high build over the area to make feathering into the existing paint easier. Will the high build primer end up cracking where it is over seam sealer?
