    Thread: Flat Vs. Roller
      Oct 2005
      New Washington, IN
      Flat Vs. Roller
      WHat differences would I get between a flat tappet solid lift cam and a solid roller cam?
      What would the real world differences in powerband, peak numbers, etc,
      Here are the two that I am looking at,
      Comp soild flat tappet 51-246-4 Grind number 294S
      Solid, Rough Idle, need higher compression ratio. MAximum street Preformance. USe 300 stall and low gear.
      Valve setting .022 Rpm Range 2500-6500
      Duration @ .050 248 / 248 lift .525" / .525"
      Lobe seperation angle 110
      Comp Soild Roller 51-751-9 Grind Number 288R
      Mechanical Roller, Choppy idle, broad power range, increased compression advised with 3000 stall, headers, and lower gears.
      Valve setting .020 Rpm range 2200-6500
      Duration @ .050 244 / 244 lift .550" / .550"
      Lobe seperation angle, 110
      Would the rooler cam make enough difference to justify its cost?
      This would be going in a Pontiac 400, with 9.5:1 compression, edelbrock heads, PRM intake, headers, etc..
      5 speed with 3.73 gears.
      The roller has less overall duration so it will idle better plus it will make more TQ. You can also make more power because of the higher lift. Add in that you are not going to wipe out a cam lobe if the block isin't perfect.
      I would probably go smaller on the roller than that and add a little more lift.... only problem is you can't go too crazy in a Poncho block with roller cams without hurting the block.
      Bret
      Bauer Racing Engines
      Specializing in late model GM motors
      1964 GTO (work in progress for 13 years)
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Not gettin done anytime soon
      2000 Camaro SS SCCA FS Car
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Oct 2005
      New Washington, IN
      Thanks, so what kind of hp or tq increase whould you think? Is it going to be worth the $300 more?
      Sep 2002
      San Jose, CA
      A roller cam is better from several standpoints. Peak HP numbers may not be drastically different, but the powerband will be much wider.
      Also, I believe the Pontiac motors suffer from similar cam oiling problems as the BBC (I'm not Mr Pontiac by any means), if this is true a roller cam will have much better longevity than its flat tappet cousins.
      I suggest you consider a cam with a a little extra duration on the exhaust side, 5-10 degree's max. I know the Pontiac has a poor flowing center exhaust port, and the extra exhaust duration will help counter act this.
      Just call me Brett
      Aug 2003
      The problem I see with both of these cams is they will make power north of the Poncho safetly zone of 5500 to 5800. The skeleton lifter valleys are VERY weak, and hate lots of lift (although a roller will help this stress), but the motor masically hates RPMs, so make it a torque monster.
      For Pontiacs, I have become very confident with Jm Butler performance
      Oct 2005
      New Washington, IN
      The roller listed here, is actually smaller than any listed on Butlers site!
