    Results 1 to 13 of 13
      2nd gen F-Body Frostbite Aluminum Radiator
      Local pickup only...
      https://www.summitracing.com/parts/FBR-FB163
      I bought this during a cooling system troubleshooting effort, but it ended up not being the radiator. So I put my old one back in.
      This radiator probably has less than 50 miles on it, so it's pretty much brand new..
      The only thing is my fan mounting bracket wore a couple of small pin holes in one of the tubes so it sprung a leak.
      I was going to keep it and then repair it when my current "Autozone style" plastic tank radiator kicks the bucket. But I'm thinking I'll just sell it to get out of the garage and I'll probably just buy another stock replacement style when the time comes. This radiator was overkill for my application.
      It sells new for over $400 from Summit by the time you figure tax and shipping. But since it has a leak, I'll let it go for $275. Just a minor repair and should be good as new.
      1971 Camaro
      Pacific Wonderland
      Where is local?
      If it breaks I didn't want it in the first place.
      69 GTO
      72 FIREBIRD
      64 BONNEVILLE FUNERAL COACH
      70 JAVELIN
      52 F1 FORD PU
      29 FORD PU
      85 ALFA ROMEO
      ASSORTED DUCATI'S
      91 BLAZER LOWRIDER
      Los Angeles, CA
      1971 Camaro
      Apr 2016
      Have any pics?
      Not sure if its coming through on the pictures, but on the engine side, a few of the fins got dinged due to the test-fitting and installation of the fan shroud.
Size:  470.9 KBName:  20230513_094159[1].jpg
      1971 Camaro
      Apr 2016
      Have a pic of the hole that needs welded?
      The little pin holes are located here... also a close up showing them.
      Name:  Radiator damage.JPG
      Name:  radiator damage close up.jpg
      1971 Camaro
      Ttt
      1971 Camaro
      Bump
      1971 Camaro
      Ttt
      1971 Camaro
      Bump
      1971 Camaro
      Bump
      1971 Camaro
      Ttt
      1971 Camaro
