      Apr 2010
      Trouble bleeding hydraulic clutch
      I'm having some trouble bleeding my hydraulic clutch. I'm using the old fashion method with someone pumping and holding while I bleed.
      T-56 Magnum
      Wilwood 260-15091 Master Cylinder
      Hydramax hydraulic clutch
      They're pumping but I can't get any clutch fluid to come out. The reservoir is full and I can feel it pumping but no fluid is coming out. Any tricks I can implement? I assume there's an air pocket in there.
      Apr 2010
      Ok, after some trial and error and finding another thread on the topic, I think I got it. I took an extra bleed fitting and drilled a hole in it so I could pull a constant vacuum on the SS hose. I put a vacuum on it for about 20 minutes and still nothing. I then jostled the bearing and tried pumping again, and it appears I finally broke the seal. Flowing good now.
      Mountain Springs, Texas
      I have had good luck using a Phoenix reverse bleeder.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Dec 2021
      HAMPTON VIRGINIA
      Don
      Reverse bleeding is the way. Ill never do it any other way again
      Feb 2013
      South Carolina
      Quote Originally Posted by KEGS73 View Post
      It is the way. Couldn't resist. Seriously though, way back in the before time when I did my first TKO conversion, I could not get the system to bleed properly until I got a Power Bleed. Still have it today.
      Dec 2008
      Detroit
      I also recommend the Phoenix Bleeder. I had to use the pulse method, but no problems after that.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
