    Thread: LSX + 5 Speed
      Socal, Ca
      LSX + 5 Speed
      Will the TKO600 mate to an LSX? Do I need any special adapters? Any help would be great!
      Encinitas, CA
      Yes it will. The correct McLeod bellhousing will do the trick. You can conatc McLeod tech at 714-630-2764 between 10-12 or 1-3 PST and they can give you the correct part #.
      Jeff Mortenson
      It's even easier than that. Use any BBC bellhousing and it will bolt right up. The only tricky part is that some bells and some blocks mess around with the 12 o'clock and 2 o'clock bell to block bolts.
      jp
      ​John Parsons
      Socal, Ca
      Jeff,
      will the elite TKO 600 internals, throw out bearing, and all the other necessary parts work with the correct bellhousing on a 67 camaro?
      I will look into the bbc bellhousing. thanks
      Encinitas, CA
      I am not sure I understand your question. Give me a call and I will help you out.
      Jeff Mortenson
      Here's another way to solv this problem
      Here's what I did. That's an LSx bellhousing with an adapter plate.
      ​John Parsons
      Socal, Ca
      Jeff,
      I will call you today. thanks
      John,
      that looks great...nice work
