      Oct 2006
      Hydraulic Fluid Recommendation
      I'm having clutch pedal fade when my car get's good and hot, I think my hydraulic throwout bearing braided line is picking up header heat. I ordered some Fire Sleeve from Design Engineering to wrap the line with but also want to put better fluid in it as well. I see that Wilwood and EBC make a high temp brake fluid but have no experience with either one. Has anyone had a similar issue and what fluid did you use to help resolve the issue?
