Results 1 to 12 of 12
12-23-2022 #1
- Feb 2005
- 201
Sniper power with battery in trunk
Hey Guys,
I searched youtube and was not able to find how to power the sniper system if the battery is in the trunk?
Please help me out.
Vince
12-23-2022 #2
- Jul 2018
- 440
Run the power cables to the trunk.. yes, that simple
12-23-2022 #3Doesn't really matter where the battery is. The sniper needs a direct positive and negative connection to the battery. So run some wire back to it. Or was there something else you're asking about?
12-23-2022 #4
- Feb 2005
- 201
It does sound simple..I purchased the sniper, ignition box, in tank pump with return less line, distributor and harnesses so I make is as idiot proof as possible for me lol
Sounds like I can literally just run wires near the right rocker area from battery to sniper.
12-23-2022 #5
- Jul 2018
- 440
Ran mine inside under the door sill plate, and out the rear seat.
- - - Updated - - -
Attachment 204225
12-23-2022 #6
- Feb 2005
- 201
The photo did not go thru for some reason?
12-23-2022 #7
- Jul 2018
- 440
20210704_134327 by F G, on Flickr
12-23-2022 #8battery to a power distribution relay panel, through a dioded relay and fuse, out to sniper. The panel will handle your ignition switched power source.
https://www.waytekwire.com/item/4634...i-Fuse-Panel-/Tracey
12-23-2022 #9
- Feb 2005
- 201
Thank you for the photo. That is very nice work!
20210704_134327 by F G, on Flickr[/QUOTE]
- - - Updated - - -
Thank you for this. This seems like a good idea & I would have access to power other items
12-23-2022 #10Hypothetically having the Sniper's fuel pump ground trigger circuit go through a common switch on it's way to the relay panel and then on to the fuel pump can be used as a hidden in plain sight anti-theft method.
Hypothetically. ;)Tracey
12-23-2022 #11
- Feb 2005
- 201
12-23-2022 #12
- Jan 2018
- Saint Louis, Missouri
- 86
Make sure you put the proper size fuse, breaker, or fusible link on the main power wire for the system as close as you can to the battery.
Diagrams I have seen from Holley either shows a fuse in an improper location or none at all.
You may want to add a fuse to the wire off of the key switch unless it is already protected.
Jim
