      Scottsdale, AZ
      T56 Mag case casting/trans tunnel interference & Off center case casting
      Anyone have this portion of the trans case on the passenger side just kiss the trans tunnel? What was your solution? I'm thinking of cutting off 1/2 inch of it when I pull the drivetrain out. 69 Camaro with Art Morrison subframe.
      I assume this is normal but are the T56 Mag case castings a little off center in the casting webbing? Seems odd. You can see the quick time bell bolt holes are level so it's not from the engine being off level.
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Santa Barbara, Ca
      Mine is the same as far as the entire transmission having a slight tilt, and I’m using a factory GM F-body bellhousing.
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      May 2010
      kitchener,Ontario,Canada
      The t56 does sit with a slight "tilt" to it ... as far as that ear .. there seems to be no issue with trimming it .. I considered the same with mine before I sold it
      Ryan Austin
      On Instagram ryanaustinss70
      Mar 2015
      I cut both places off of my t56 so I wouldn't rub the tunnel.
