    Results 1 to 9 of 9
    Thread: Manual brakes
      Manual brakes
      Am I crazy for considering doing manual brakes on my Nova? The car will have a pretty healthy big block so I知 sure having enough vacuum will be an issue. I like the thought of how clean the firewall will be with a manual setup. I知 not a huge fan of the aesthetics of the hydroboost sticking out and extra lines running down to the power steering pump.
      The car has 14 inch Baer rotors and 6 piston calipers on the front and 13 inch rotors with 4 piston calipers on the rear. Will there be any issues running this setup in a car that will see way more Street time and car show cruising than it will auto crossing.
      Jul 2022
      Michigan
      There is a thread "MC Recommendations" that would be a good starting point (I cant use Links). Have you had a car before with manual brakes? It can get tiring on the leg some times but overall I personally like them. If you set it up correctly I wouldn't see any problems.
      Mountain Springs, Texas
      Master cylinder bore, pedal ratio and pad compound selection are key to decent manual brakes imho. Miss any one and they will suck imho….
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Quote Originally Posted by hotrodsofthemidwest View Post
      I have manual brakes on both of my cars and with your big brakes, it should not be a problem. Given a fairly typical 6:1 pedal ratio and a 15/16" bore MC (the Baar Remaster is a nice option) should work very nicely for you.
      I have manual brakes on both of my cars and with your big brakes, it should not be a problem. Given a fairly typical 6:1 pedal ratio and a 15/16" bore MC (the Baar Remaster is a nice option) should work very nicely for you. Andrew
      What pads?
      a67
      Orange County, CA
      You can definitely get those working nice going manual
      Sep 2001
      Accord, NY
      I have a C5 manual setup with a 7/8" mc and EBC yellow pads. It's perfect.
      68 camaro - SOLD
      Quote Originally Posted by a67 View Post
      What pads?
      a67
      Hawk HP
      Quote Originally Posted by Rick Dorion View Post
      Hawk HP
      This is the key to manual brakes. High friction pads. Both of the above are a step below a full on racing pad. But it does make manual brake systems work.
      Besides the proper M/C bore, pedal ratio, and caliper bore size, the pads are the left out denominator. Can't go cheap here.
      a67
