      Aug 2015
      dakota digital installation
      Has anybody replaced their factory gauges with the DD setup in a 69 camaro? Did you have to remove the cluster, dashpad, etc... or can you do it easier by just removing the current setup. I just had the dash pad adn gauge bezel replaced, would hate to have to undo all that work....also it looks like you can work around the streering wheel and column....maybe a little more tricky, but less work ...looking for any advice...I am lookng at the rtx gauge package. Thanks, JR
      Mountain Springs, Texas
      Pretty sure you have to remove dash pad, lower column and remove cluster. At least that is the way I have done it. It may be possible to do it the way you describe but I have some doubt.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
